I have a '97 Camry 4-Cyl that I bought new. It has 88K miles on it now, most of it in-town driving. After changing the oil myself every 3K miles or 3 months with Valvoline All Climate for 55K miles, I switched to Mobil 1 5w30 3 years ago on the suggestion of this board and a Toyota mechanic. At that time I had an oil pan leak and had Toyota drop the pan to fix it. No sludge at the bottom of the engine, but I switched to Mobil 1 because I wanted to extend the OCI to 6 months since my son would be driving the car from that time forward. I did several short OCIs with Mobil 1 (3 months) and observed that it turned dark very quickly. The 3rd batch stayed clear for the entire 6 months. Now that my son is in college, he drives 400 mile one-way trips to/from school and brief in-town trips in between. I now use Mobil 1 Extended Performance 5w30 and change it once per year. It is still amber colored after 1 year.
My opinion is that summer in-town driving was greatly stressing the Conventional oil and that I was on the verge of sludge based on the rapid color change of the Conventional oil in the summer, but not the winter. Mobil 1 claims that their oil can withstand 400F and I believe that it provide thermal margin for this hot-headed engine.
After 20K miles with Mobil 1, the semi-circular plugs under the valve gasket started leaking, so I had the valve cover removed to fix it. The head was clean, but I could see some crud in the corners and in the top of the valve cover that did not get much oil splash.
Since you have stated that you want some margin and peace-of-mind, I suggest that you consider Synthetic oil, especially in Alabama. I am in Tennessee, so you are hotter.
BTW, I have kept the cooling system kept in top condition, so that potential variable was never an issue.
I have read that there are 3 design issues with these engines:
1) Small oil ports to the head
2) Oil ports channel right over the hottest part of the combustion chamber
3) PCV system is marginal and clogs, which makes the other problems magnified. Remember to maintain that PCV system!
Best Wishes as you motor along!
