Engine in question is a ford modular 4.6. Original recomendation was any 5w-20 meeting ford spec. (Many conventional oils meet the spec). Engine is shifted at 7200 rpm under race use, but has a 4200 stall converter so spends even its street miles above 3k rpm all the time. Has a hot Crower cam (.581 lift), higher compression, and aftermarket heads/pistons/con rods.
Engine is all ECM controlled, so fuel dilution isn't an issue. The engine is happy to idle in traffic and is very comfortable to drive so it gets driven any day it doesn't rain (even to work and what not). It gets maybe 1/6 of the miles put on the car at a racetrack. Usually about 500 miles a month on the track, with 2k to 2500 street driven miles. Not just drag but track racing where the engine will stay above 4-5k rpm for a few hours on a good day (oil temp can push 280F+ with oil cooler)I tend to use 30wt or thinner 40wt oils depending on anticipated usage.
Last few fills have been Valvoline VR-1 synthetic 10w30 (the cobalt blue stuff). I'm not particularly interested in getting every last mile out of the oil for obvious reasons. What would you guys suggest for an OCI?
