- Joined
- Dec 20, 2022
- Messages
- 317
Hi all,
I'm looking for your thoughts, I am pretty set on 5k OCI w/ Valvoline Extended Protection 0w20, unless convinced otherwise, but it is always good to get more opinions.
I'm about to purchase a 2023 Blazer w/ the 2.0L engine. I'm debating the switch to 5k OCI based on my driving habits. I've read through a ton of articles, talked with a couple engineering buds, and looked at some tear downs of the engine. Looks to be a solidly built engine, disregarding the first few years they were in production. Here's the tear down of an older model:
I had a GMC Terrain w/ the 1.5L before, did oil changes every 7500 and was astonished at the amount of sludge I saw on the oil cap after 110k miles. My driving is mostly shorter trips (5-10 minutes), with the occasional 45 min - 2 hour trip every couple weekends. A shorter OCI should help cut down on sludge, fuel dilution, condensation in the oil, and just make the engine last longer without major problems. I would potentially consider 4k OCI and a different oil for this little turbo engine.
My plan is 5k OCI with the OEM PF66 filter and Valvoline Extended Protection 0w20. PF66 seems to be well made, with the newer generation having an e-core instead of louvres. The Valvoline EP 0w20 has exceptional oil analysis, and I've been a Valvoline fan for the last few years, except for 0w16 (TGMO only for my Camry). The PF66 can be had pretty cheap off RockAuto for less than $5 and I tend to just buy 5 or 6 at a time.
What are your thoughts?
