The SAE weights - 20, 30, 40, 50, etc - are not proportional to the actual viscosity they are are indicating. For instance, a typical 20 weight oil does not have half the viscosity of a typical 40 weight oil.
Looking at the numbers for two commonly used (and discussed here on BITOG) oils we find Mobil 1 Advanced Fuel Economy 0w20 has a 100C viscosity of 8.7 which is two-thirds as thick as the 12.9 of Mobil 1 0w-40 FS.
Looking at the HTHS measurement we find the difference between these two oils is even narrower, 2.7 of the 0w-20 is three-quarters as thick as the 3.6 of the 0w-40.
While obviously there is a difference between these two oils; the difference may not be as large as some of the thick/thin arguers make it out to be.
