I'm comparing two oils right now. Rotella T6 5w-40 and Mobil 1 Turbo Diesel 5w-40. As with other brands and grades, there is a sizable difference between the two viscosities at 40c.. The Mobil is a shade over 100 and the Rotella is in the upper 80's... Why, if they're both 5w oils is there so much difference? As far as I can discern, the T6 is more like a thick 5w and the Mobil is more like a thick 10w... The 100c viscosities are closer together in the 14 range...
Moving on to drawing conclusions, would that mean that the Mobil would likely be more shear stable? It's HT/HS is 3.9 while so far I haven't been able to find the T6's...
