OBD-II code scanner...
Fayetteville, NC
What's a good one to get? should be < $100 Our cars are Ford, BMW and Hyundai... I might want one that can read some of the BMW specific codes AND generic codes... Anyone has any advice?
DealExtreme has the Autel MaxiScan MS509 for about $65 shipped. It's the exact same scanner as the $130 CenTech at HF. It'll take a month to arrive. It worked well reading Hyundai-specific codes on a 1999 Elantra. For the price, there's no touching it.
But will those read prorietaty BMW codes? It looks like only the Peake can read those - but then I can't use it on other cars...stupid! Perhaps I should get one that can read MOST Bimmer codes and hope That if i get a code it will not be one of the 'special' BMW codes... I was recommended this one too: perhaps this is good enough for basic code reading and erasing? http://www.amazon.com/Equus-3100-Innova-CanOBD2-Diagnostic/dp/B000EVWDAK
If you need to do some special codes, I'd wait until you have a justifiable issue, then buy the BT scan tool. I'd then either get a super-cheap one to cover, or else hold out for the autel MS609, which will be able to do BMW ABS codes (and abs for a ton of others) as well as being a good scan tool with tons of data.
I have an Acutron Pocket scanner. It reads, estimate whether a severe or not severe problem and will clear codes. ~ $80 at Advanced Auto Parts about 2 years ago. Works just great on my Mazda CX7 and my daughters Santa Fe.
I got Actron CP9575 from Advance Auto when it was on sale for $99.99.I used their $40 off coupon and it amounted to around $65 including tax.It is not the most basic Actron.
