I am not convinced this is a better mousetrap lots of dissatisfied purchasers at Home Depot.
Clearly for the toilet seat warmer.Nice discussion, but I am more intrigued about the oddly located electric receptacle behind the toilet. Needs to be a GFCI in case the pooch decides to get a drink or the grand kids are flushing their stuffed toys.![]()
I read the reviews and other Kohler toilet reviews. Same complaints about almost any Kohler toilet. They all same to have a rating above 4 and under 4.5I am not convinced this is a better mousetrap lots of dissatisfied purchasers at Home Depot.
Some put an outlet there for a bidet seat. really the outlet is in the wrong place it should be on the right side, about 6 inches from center and 10'' from the floor.Nice discussion, but I am more intrigued about the oddly located electric receptacle behind the toilet. Needs to be a GFCI in case the pooch decides to get a drink or the grand kids are flushing their stuffed toys.![]()
They are very good and common. I have had many with bad fill valves right out of the box. I would say 20 out of 500, which is alot.I've installed a few of those Kohler toilet systems in recent years. Never had a problem. Seem to work well.
(2) two flushes often needed to clear the bowl of solids
Come on, guys ! That's too much info !Doesn't do the greatest job with solids, though.
You realize it's very common to daisy-chain GFCI outlets ? Our house has (3) bathrooms and (1) GFCI but ALL of the outlets in our bathrooms are protected.Needs to be a GFCI
Leave the bolts out and get back to me on if the mechanical attachment is unimportant.Hopefully the toilet is supported by the floor.
The mechanical attachment is unimportant. The toilet should be shimmed to eliminate any wobble and then caulked to the floor.Leave the bolts out and get back to me on if the mechanical attachment is unimportant.
The toilet is a water saving (I think identified as a 1.2 gallon) flush. The limited testing shows one flush clears the solid.Okay so I'll ask the Eternal question is it a solid strong flush, one time two clear all the material or is it a double flusher to conserve water by flushing it to or more times? Also is the toilet seat a fast Closing one or does it close slowly if you let it just fall.
I'm really tired of these Energy Water conserving toilets that you have to flush three times just to get the material down and possibly cause a clog.
Also I will add the diameter of that hole does not seem very big. People around this house often ball things up and try to flush them that would be a cork just waiting to happen. I do like the streamlined base for ease of cleaning which is really nice then to fiddle around with all those nuts down at the base on the old style.
The toilet seat was a slow close, but was plastic. I installed a slow close Bemis wood seat, but doesn't match so well with the toielt, I may change to another soft close wood seat at a later time. The install hardware for this Bemis was poor quality, the seat was purchased from Home Depot. Prior, I had purchased two wood Bemis seats from Wal Mart- the Wal Mart seats came with significantly better mounting hardware. Walmart recently dropped Bemis seats from their retail stores.
Like you, I was not expected the black tube to be so small. Only time will tell.
Home Depot has sizing charts on display in front of every toilet they have at the retail store- super easy to compare sizes at one time.Thanks for that info that helps a lot I am in the toilet market right now and will be making a Home Depot run I need to take some measurements first. As I do want to have a higher seat style toilet not one of these small low 1964 bucket type toilets. So a little measuring and a visit to the depot they have a fairly big toilet section where I live here in SoCal! And I should mention the prices are fairly high as well! The days of $75 toilets seem to have long gone.
Thanks again
I thought he was talking about the integrity of the subfloor after having a leak for a while. Plywood delaminates, and gets “punky”.Leave the bolts out and get back to me on if the mechanical attachment is unimportant.
I really don't know how you got that out of what I wrote.I thought he was talking about the integrity of the subfloor after having a leak for a while. Plywood delaminates, and gets “punky”.
I didn’t think he was suggesting leaving the bolts out.
I will say it - the mechanical attachment is unimportant. The toilet should be secured to the floor with caulk and not depend on the flimsy brackets to secure it in place.I really don't know how you got that out of what I wrote.
I said i didn't think i felt good about the plastic horn attached to the toilet flange and then metal brackets attaching the toilet to the horn.
(note id be better with it if there was some sort of metal insert or sleeve in the horn.)
Others said the mechanical attachment was unimportant.
I said leave the bolts out and let me know if you still feel that way.
