Originally Posted by Bjornviken
Originally Posted by edyvw
Just go for the r3. If your roads in the winter have more ice than snow then go for hakka 8.
Typically it's more cold than anything else but then we will get a dumping of snow and the roads are a mess of thick sloshy snow until they clean it up. Ice is only a concern sometimes because of the amount of salt and brine they use.
Thanks for the recommendation along with all the others.
Let's go back on subject ok. If dumping of snow is just temporarily issue, then question is: is it worth sacrificing dry and wet performance for several days of deep snow? Any winter tire will do good in those conditions, maybe R3 will do best, but based on tread design of R3 I cannot imagine being one of better performers in dry. That is what would be consideration for me. How much of value for you is dry performance or wet performance and how annoying for you is that "squishy" feeling winter tires have?
I have no problems in wet and dry tarmack with the r2 wich is the older version. Suprise snow is a nightmere and there is the real danger. And the "squishy" feeling is not what you get with nokia tyres.
I find R2, which I have horrid in wet and dry compare to any winter tire I had, except Hankook W300 and Sava Eskimo S3, but Sava is kind of same tire like Nokian, great in snow and ice, horrid in everything else.
Let's not forget that Car and Driver did snow track in Sweden with R2 only 0.17sec faster then with Michelin Xi3.
