I thought so, thank you.It won't. Bad capacitor will result in a motor that won't run and maybe very slowly if you nudge it.
It doesn't.This is interesting. I wonder how the capacitor affected the noise level of the motor.
First, it was on a heat pump, and during winter (in Ohio) it would run for long periods of time. The cap didn't give up until summer though. I think it shifted capacitance or something, causing "some" noise. It wasn't a really loud noise like something was loose, it was more like a loud humm that I could tell just wasn't right, kinda like the motor was laboring. Little bit of a slow start too, but it would always start.Can you please elaborate? Like were there any other symptoms besides being super loud with capacitor being bad? Thanks
I agree on the non detergent oil and I assume the 3-in-1 motor oil is non detergent (I may have to contact them). Their literature does not mention cleaning ability like their regular 3-in-1.I like non detergent but any motor will work. Reason I do not like 3 in 1, when it was in a metal can years ago, the can always rusted badly. That itself told me something.
If there are no oil cups on your motor, your best choice is to replace the motor.
Thanks for your valuable input. Yes, I am seeing prices all over the place - starting from $100ish to $300.I agree on the non detergent oil and I assume the 3-in-1 motor oil is non detergent (I may have to contact them). Their literature does not mention cleaning ability like their regular 3-in-1.
.................................................. example of multi fit motor, $95 at Zoro (mailorder unit of WW Grainger):
View attachment 109499View attachment 109503
If you choose to buy a new motor, do a thorough search for best price. There is a good mark up on them. I have access to jobber type HVAC suppliers like Johnstone Supply. Often times HVAC equipment has proprietary components such as the motors, but the HVAC suppliers will have quality "will fit" generic versions that I found to work just fine. Just my experience and opinion.
Also, some motors have 2 capacitors: a start capacitor and a run capacitor.
If it's a sleeve bearing with no built in way to lubricate it, then trying to lubricate it yourself is a loosing proposition. It may sound better for a day or two but not long term. Sleeve bearing motors with no built in way to oil it are made to be replaced. I would order a fan motor. If you are able to squeak a little more life by oiling it then you are ahead of the game. If it starts sounding really bad then you have the new fan motor on the shelf to install.Do you think removing the motor and then lubricating the shaft with 3 in one oil would help in terms of noise reduction and ensuring get a season out of this motor?
Or should I just go ahead and order the motor for replacement? Thank you![]()
Here is what I am seeing as the direct OEM replacement: https://www.lennoxpros.com/condenser-fan-motor-1-4-hp-208-230-volt-1-phase-825-rpm-100483-43/p/12Y65We don't have your motor number to investigate prices. On my example above, I noticed that some vendors have Chinese models for the name brand Century motor that is already a generic replacement of the OEM. Does that make sense? Plug your number into the search at Johnstone Supply and see what they come up with, then shop the internet for best price.
Following up on my above comments: A company like Lennox might have G.E. manufacture a motor for them and Lennox puts their own OEM number on that and sell it appropriately marked up. I use generic versions of the OEM marketed by "name brand" motor companies, not Chinese knock offs of the generic versions. Confusing, I know. Some name brand motors are Emerson, Fasco, Marathon, Century, Dayton (Grainger brand). Sadly, I think most, if not all, are not made in the USA anymore. Avoid Chinese knockoffs of the import name brand generic motor.
Maybe , maybe not . I lubricated my fan motor several years ago and it's still running smooth . Nothing to lose by trying .If it's a sleeve bearing with no built in way to lubricate it, then trying to lubricate it yourself is a loosing proposition. It may sound better for a day or two but not long term. Sleeve bearing motors with no built in way to oil it are made to be replaced. I would order a fan motor. If you are able to squeak a little more life by oiling it then you are ahead of the game. If it starts sounding really bad then you have the new fan motor on the shelf to install.
Kind of. Except, it is sometimes difficult to I.D. the correct part (i.e., problem when I helped my son replace his furnace exhaust fan motor). Probably looking at $600 to pay a technician to pop a new motor in.This is funny .
