Noise from passenger side rear wheel?
Lansing, MI U.S
Hello. I have an 2001 Acura Cl which has 112k on it. It makes a kind of humming or whistle noise from rear wheel. The noise occure from 5 mph. It is getting louder when the car is faster. I guess it is from the rear hub bearing. What do you guys think about this? Thanks.
Silicon Valley
Start by rotating the tires to rule out a tire. Note if the noise gets louder or softer with applying the brakes or making a turn. (Check left and right turns.) Jack up that corner and spin and rock the wheel by hand and ensure the parking brake is releasing. Then report back.
Silicon Valley
 Originally Posted By: RyanHeo
I don't think any turns make the noise worse because it is from rear wheel. Thanks.
What I was suggesting is to see if the noise becomes louder when the weight is transferred to one side when making a long steady turn, like on an exit ramp. If it does get louder, it's probably the wheel bearing. But check the other things first to rule them out.
