Hi guys,
Since I did the tires rotation on my car, I can hear some sound, like humming sound or a little "zzzzzz" coming from the rear.I just cant tell if its the differential or the tires or one of the rear wheel bearing.
The car is a 2005, Cadillac CTS, automatic with 3.6l with 112k miles on the odometer.
The sounds can be noticeable at:
60-70kph
80kph
115kph-120kph.
between those range or lower than 60, i cant hear a thing.
I cant point if its the tires, differential or wheel hub needs to be change.
I flushed the diff. and put new fluid in it but didn't change a thing. The old fluid was in nice color almost like the new one. I change it every 50k kms.
At 60-65 its more a zzzzzzz just like winter tires.
at 80 and 115 its more like a humming noise.
If its a wheel bearing, since I have the wheel hub assembly with bearings, speed sensor et abs sensor in it, if I try to shake the wheel, will there me some loose if the bearings are bad?
60-70kph
80kph
115kph-120kph.
