Noco Trickle Charger - leave plugged in all the time?
Cow Hampshire
I have a Noco 1 amp trickle charger for our vehicle that sits.
I can leave plugged in always or add a smart plug i have in front only charge a few hours a daily. Is it worth adding smart plug ?
Thanks
If it is a NOCO Genius 1, it can be left plugged in indefinitely, it will maintain voltage after it reaches full charge. I generally have mine on the ‘11 Express in my sig to counteract the keyless entry system from draining the battery.
I have genius 1 chargers plugged in continuously for years now. No worries.
They aren’t as optimal as battery minder chargers that keep a continuous float charge on the battery. Noco chargers go into a dormant state and wake up when the battery goes below some threshold. That’s fine, but I prefer a float charge. Still, I run the genius 1. I do wish it had an actual voltage readout…
@andrew_j, without actual data, it's difficult to be acurate; see what I did there? Being conservative, I would initially leave the charger on for 8 hours and then repeat once more 24 hours later. After 2 successful 8-hour cycles, I would then activate the battery charger for 20 minute intervals once a week to keep it charged.
This is assuming that your 1A charger is not a smart charger and my data assumptions. Use this recommendations at your own risk.
It’s a NOCO 1 so it is a smart (-ish, no chargers are truly smart, except maybe $$$$ ones), and has some logic to go through its modes. Like most every other out there.
Without knowing typical parasitic draw, we don’t know if the 8-hr charge is worth anything. Will it get it to 90%? 98? 100? Most chargers leave a bit on the table and aren’t truly 100%, which is why I prefer ones that float continuously, since they at least offset losses and approach 100%.
Turning it off and on again exposes everything to never ending 14.5-15V stresses. Sure, every time the car turns on it sees that. But now we’re programming that in on a daily cycle. All the caps on boards and things that are constant hot get that may more slightly higher voltage cycles. Does it matter? Maybe not. But I know it’s less stressing to not do it.
2 hrs is only appropriate if you know your parasitic and know that a full charge is achieved. It could be too much or too little. Is that bad? Maybe not, you’re better off having it do something than nothing. If the charger lets a bit of battery charge leak back that could also add more parasitic.
Way too easy to over think it!!
I think my response requires a review. Your comments don't seem to line up with my recommendations.
I based all my recommendations based on that opening statement and other factors like (estimated Ah/SOC) and charger amp setting; 1 A.
+1
The NOCO products are all "smart" chargers. It can be left connected continously.
Thank you for clarifying!
Pretty much everything is microprocessor controlled these days. Only something 20 years old, or the most cheaply sold chargers are not.
Even the $7 ones on Amazon are smart chargers. You pretty much have to go out of your way to find one that is not microprocessor controlled.
Assuming OP's "Noco 1 amp trickle charger" is a NOCO genius , YES Plug it in any time you are not driving or riding 24/7/365.
I have one motorcycle ( Harley ) I have connected to some kinda battery maintainer 24/7/365 unless I'm riding, its connected the last 25+ years or so. I get about 5 years and have to replace the battery.
