Originally Posted by motorguy222
It doesn't have the resistor but it does have a pickup under the distributor cap, not sure if anyway to check it. I will have to wait a little while to check for spark, I seem to have diverticulitis, what my pcp thinks anyway and am on an antibiotic and don't want to do much mechanical work right now. Thanks for the help guys.
This is a Port Injected engine (8 Injectors)? If so the Sensor in the distributor is for Camshaft Position (CMP).
Probably puts out a 1X Signal, Meaning it switches High to Low once every Camshaft rotation, And once every 2 Crankshaft rotations. This is a 5volt Hall Effect Sensor & has 3 wires...
5volt reference
Ground
Signal Circuit back to the ECM
*Because this sensor only switches once per 2 Crankshaft rotations.....It's possible to see the High-Low signal/pulse with a DVOM.
*Hook the DVOM to ground & back-probe the Signal Circuit & have someone crank the engine.
*If the CMP is functional.....You will see a 5volt to Zero volt swing.
IIRC.....This engine will run without a Camshaft position signal? Someone correct me if I'm wrong about that!
The Crankshaft Position Sensor (CKP) can be checked the same way, But you will need to barr the engine by hand with the key-on & ASD relay removed. The reason being is.....The DVOM will not pick-up the 8X signal per Crankshaft rotation, Which actually comes out to 16 CKP pulses to 1 CMP pulse.
With that said....Check for spark at the Ignition Coil, If you have spark....Pull the Distributor Cap & Ignition Rotor, Inspect the Rotor for being burnt.
*If you have a black dot on the underside of the rotor.....The secondary Voltage has blown a hole in the Rotor & recommend at least the Cap & Rotor be changed.
*Secondary holes in the Rotor can be caused by Open Ignition Wires & Worn spark plugs with wide gaps.
