- Joined
- Nov 28, 2021
- Messages
- 805
So it is TBI?Throttle body injector sprays fuel when cranking.
Will it crank in neutral? Maybe it will start in neutral, if so it may be the neutral safety switch, if it has one, which i think it does
IS there a throttle position sensor?
is there a crankshaft position sensor?
is there a camshaft position sensor?
.....if so check them via specs in manual
assuming you have good spark and good fuel, and mice have not crawled into the intake to block the air flow, it must be one of those sensors, again assuming mechanical is all good.
