Originally Posted By: brianl703
You can connect a jumper cable from the battery positive terminal to the terminal on the starter solenoid where the battery cable is connected. This will bypass the battery cable and allow the engine to start if it's bad.
Or you could try jump-starting it to rule out the Optima battery.
Hey, how about checking the voltage at the battery when you try to start it? How low does it drop?
The battery voltage does not move when you go to start the car. It is like the starter curcuit is not connected to the rest of the car.
I bench tested both starters, and the solenoid kicks when I jump them.
