1994 Chevy C1500 2wd 350 277K miles. I have had the truck since about 175K and the starter in it is the one it had when I got the truck.
Today when I started it up the starter kept turning over the motor. Even when I turned the ignition switch the starter was still turning the motor even though it quit running. I had to disconnect the ground wire on the battery to get it to stop. Thought it was a fluke so connected the ground wire and attempted to start it and the same thing.
I took off the starter and took it to Advance and Autozone. Both tested it and both said it was good. This lead me to think it was the ignition switch (I was hoping not as do not look forward to taking on the steering column). However I hooked my meter to the wire for the 12v to the solenoid from the ignition switch and when the key is switched I get 12v (actually 12.51) and when you let off the switch the voltage goes away.
Could this still be the starter (or solenoid) and it is just not something that the machines test for? The cheap rebuilt starter for this truck is just $30 bucks so not to expensive just to try but....
I also thought about just adding a remote switch in the cab to the solenoid instead of using the wire from the ignition switch or possibly both (remote switch and rebuilt starter) to remedy both of the issues I think could cause these symptoms.
Any help appreciated.
Thanks
Thanks
