If somebody knows, please school me. It is winter and the Rat is up to its usual tricks. It likes to spend the winter laid up. This time it is the starter. 'Zactly what, I dunno. Turning the key gets me a click. It is coming from the fender mt'd starter relay. The starter mt'd solenoid is quiet.
The starter is an exact copy of the original Ford gear reduction gear starter. I mis diagnosed a dead short as a bad starter and a 38$ new starter looked good. Rebuilding the starter would cost me more than that. The original starter worked but rattled like a maraca. In goes the clone. Both starters test fine. So does the relay and wiring. I put the starter on the fender and hooked it up to its wires. Turned the key and it worked. In the truck. nothin'.
The starter is hand assembled and is a breeze to work on. Even the original came apart easily. I swapped solenoids, no sweat, T25 screws. First casualty was the braid to the brushes parted on the donor. but removing the brush pack was a snap, tweaker screwdriver stuff. the armature and stuff looked OK. But after I pulled out the armature, I saw a ball bearing stuck to a magnet. That explained the rattle. That and a bad nose bushing. My Franken-starter consists of the clone's reduction drive, field magnets, housing and brush pack. I used the original solenoid and armature . The clone's had a whiff of smoke. I'll follow up with my results after I put the starter back in.
