No-splash oil drain pan?
New York
I typically change my oil with various cars up on plastic ramps, so there isn't a lot of room under there. I find that the oil drain pan I have used for years always creates splashes of oil, particularly if the oil is hot and flowing fast: https://www.autozone.com/shop-and-garage-tools/oil-drain-pan/p/flotool-drain-pan-16-quart/700706_0_0
Is there a better drain pan that cuts down on the splashes of hot oil all over the place? One way I mitigate this is to slide a plastic tarp under the car first. It makes it easy for me to slide under the car to do the work and catches the splashes, but it would be nice to not have a mess to clean up after each oil change.
You want oil not to splash???
i use a plain jane round pan that is about 5 inches deep and I don't have any splash issues. although i have never used the pan in the link you provided, it seems the pan is too shallow possibly causing the splash.
I have a drain pan/container similar to your, except it is round and larger. I too have a problem with the oil splashing. I bought one of those mesh pads that they use on commercial floor buffers and cut it to fit the pan and removed a small section in the middle for the drain plug. The oil flows right through the pad and no more splashing.
The oil comes out of the oil pan in my V-10 Ford F53 chassis motorhome, with the stream directly hitting the front axle. I have to hold a large plastic funnel with a piece of old heater hose on the end of it, to catch and redirect the stream of oil into an oil pan.
Such a good design. Only made that mistake once.
You can buy a plastic mesh splatter pad at AAP., Amazon, etc.
Cut to size: https://www.fcpeuro.com/products/no-splash-pad-22-square-lisle-38780
This Lisle oil pan has a rolled inner lip to redirect splashing back into the pan. However, it won't work if the oil is discharged at a very high velocity where splashing will spray over the height of the side walls. That can be mitigated by lifting the vehicle as low as necessary to clear the pan while accessing the drain plug.
I just use an old Rubbermaid accessory dishpan. No splashing.
contents get emptied into a re-purposed 5 gal gasoline jug.
I would get one with straight side walls - not this one -
I have this same pan and have no problems with splashing oil.
I used to run into this issue, and my solution was to put the drain pan on top of a wood block so there was just enough room to get my hand in and remove the drain plug. Less distance for the oil to gain velocity before hitting the pan, and less space between the top of the pan and bottom of the engine meant I (and the driveway) got hit a lot less.
Then I got an EZ-Oil Drain valve with their screw-in nipple and some clear tubing. Oil draining directly into an empty jug through a tube means no more splashing problems. That's still my solution for the F-150.
As others have mentioned, an extractor can be even better if it suits the application. That's what I do with the VW.
