Quote:
WHAT:
EXi is Briggs & Stratton’s new durable and reliable engine platform that will become standard across all OEM partners and mower lines, phasing out the current Quantum engine over the next couple of years. EXi is the first walk-behind lawn mower engine that will never need an oil change—ever. The engine, launching in early 2015, is made in the USA of U.S. and global parts at Briggs & Stratton’s Poplar Bluff, Missouri plant.
WHY:
Briggs & Stratton PowerPulse research shows that, from starting to use to maintenance, consumers want easy. EXi is the next generation Briggs & Stratton lawn mower engine made for consumers who want easy and expect durability and reliability. Because the engine requires no oil changes, consumers need to simply “just check and add” oil for as long as they own the mower. In addition, no tools are required to change the air filter—it doesn’t get any easier than that.
HOW:
The engine experts at Briggs & Stratton made significant design changes to the engine in order to keep the oil cool and clean, two necessary factors in extending the life of the oil. To provide consumers with a durable, easy-maintenance engine, changes include:
● An optimized combustion chamber for easier starting, more power, lower emissions and improved fuel economy.
● The addition of a radial seal paper air cleaner keeps debris out of the engine, helping to extend the life of the engine.
● The fuel neck is larger and angled toward the operator, which makes adding fuel easier and less messy.
● The use of lighter parts making it the lightest engine in its class for easier maneuverability.
All of this was done without sacrificing the Briggs & Stratton quality, power and cut that homeowners have come to expect.
WHERE:
Briggs & Stratton’s EXi engine will be featured on Toro, Husqvarna, Troy Bilt and Craftsman mowers in early 2015 and available at major retailers.
So this lifetime oil they adding will be a synthetic or conventional?
