Have they phased out green coolant? All I see now is this "one brand" for all coolants type coolant.Is this what we are to use now on a flush and refill?
2-EHA is a plasticizer, and I believe it to be the cuase of the infamous deathcool name to dexcool. GM had some incompaitible materials in the engines that were using dexcool, and that why it gelled, imo. I do not believe it to be a fault of dexcool that caused gelling. Many other car makes are using OAT/HOAT coolants without problems.quote:
Originally posted by nel:
If you really want the traditional formula, try Zerex MaxLife. It's designed for older vehicles and appears to have the corrosion inhibitors (phosphates, silicates) those vehicles were designed for.
On another note, there's been some discussion regarding the new all-purpose coolants such as the new Prestone formula. When I read the label on a jug, it appears to have 2-EHA, one of the organic acids used in DexCool. I've read that this compound is a plasticizer, so I'm not so sure it'll be safe on older vehicles--especially with regards to gasket materials. Correct me if I'm wrong.
Nah, don't panic. Drain, flush to clear water, and refill as usual. (distilled or de-ionized water highly recommended, though) Use one of the commercial cooling system flushes if you suspect corrosion. If you're uncertain about the radiator cap and thermostat, REPLACE 'em! (They're too cheap to lose sleep over.) If you have any cooling system leaks, they should be attended to regardless of type of antifreeze/coolant used. A pre-emptive used oil analysis would be a good idea to verify that coolant isn't making its way into the sump due to gasket failure. The rumor that extended life products are death on soldered up brass radiators has NOT been substantiated. (Not the same thing as saying they are false - just that no one has demonstrated damage to that type of radiator in controlled testing.) As to hoses - no difference as far as I'm aware. The main benefit of the "OAT" and "HOAT" products is longer working life due to more stable corrosion inhibitor chemistry and correspondingly longer water pump seal life. Pop the radiator cap routinely to keep a close check on radiator level - and don't trust that the overflow bottle will confirm that the radiator is actually full. If in doubt about the tubing from the radiator fill neck to the overflow bottle and the tube from the overflow bottle's cap to the bottom of the bottle, REPLACE 'em. A pinhole in either could allow air into the cooling system upon cooldown. If these recommendations sound more like good, common, maintenance sense than exotic rocket science, go to the head of the class.quote:
Originally posted by BlueOvalFitter:
Will we need to change hoses,gaskets,radiators,etc?Or,can we just flush and refill? I'm so confused!
You can buy green coolant.quote:
G 05, which is HOAT, is precharged already and can be used in diesels w/o the addition of an SCA initially. It may require the addition of an extender if you want to make the interval longer. Zerex makes G 05 (thought the Zerexc G 05 is completely clear), Ford and Chrysler have their own G 05 (dyed an orange/red), and Mercedes has been using G 05 for quite some time.quote:
Originally posted by rkpatt:
Any Ford Diesel experts ? Can I safely use HAOT in my 1994 Ford 7.3 idi diesel truck and is it compatible with the SCA DCA4 / SW16 anti-cavitation additive ? -thanks
