No EGR/DPF Diesel better off with A3/B4 oil vs HDEO ? Manual specs both....
BDK
So I find myself in the possession of a 2013 ZD30 Common Rail Diesel Nissan Patrol no DPF and EGR has been deleted....
I'm in Australia and there seems to be a lot of issues here with these engines (mostly the previous gen Direct Injection no so much with the Common Rail)....but from doing a bit of research there seems to be issues with cooling piston no 4 and high EGTs (Exhaust Gas Temperatures) that blow these engines....a lot of people here use HDEO oil for diesels mostly 15w40 mineral or semi-synth....I wonder if that has something to do with it......on a lot of the forums here the most recommended oil is 15w40 15w50 for diesel engines (all these oils here are mineral or semi)..
Also moving form the UK I find that mineral oil and semi syn. is mostly what you find in the shops here and full syn is quite hard to find / limited ....where in the UK pretty much all oils were full syn...
And what made me post this is that I've read here somewhere that if you have a diesel without DPF/EGR you are actually better off using A3/B4 oil instead of diesel specific... I've attached below pictures of the manual (this is from 2013 so I'm assuming a lot has changes since then regarding engine oil...)
An interesting footnote in the manual is **For Pickup models in South Africa only API grade CF-4 or JASO DH-1 grade oil is recommended**
And this is what I got to go in it as it's been run on mineral 15w40 for the last couple of years (info from the previous owner)...
