don't forget, though, the flow demands of an engine increase with rpm from centrifugal effect at the rod journals. so if the pump maintains the same pressure through the whole rev range, it is flowing more through the engine at high rpm than at low rpm.quote:
Originally posted by Chevy Guy:
Pressure is determined soley on the clearances of the oil passages in the engine combined with the bypass valve setting. Flow is realtively low in an engine, its not like water flowing out of a hose.
i know that's what you said, that pressure and flow weren't necessarily related, i just wanted to clarify another phenomenon to add to the complication of the function.
-michael
