Compression testing yourself is a good idea, however, if it were my engine I would perform a leakdown test.
For those unfamiliar with a leakdown test, it is as simple as pressurizing the suspect cylinder with shop air via a leakdown kit and observing whether the cylinder holds the pressure.
A leakdown test will allow you to actually hear where the leakage is coming from if there is any. Leakage from the intake valve will obviously result in hissing from the intake, Exhaust valve from the exhaust, and if the piston rings are at fault you'll hear hissing from the oil cap.
