Elkins45
Site Donor 2026
Jump to 11:00 to discover why it failed. This is disconcerting because the Frontier was previously the number one choice were I to have to replace my Titan.
The VQ has always had an internal water pump since 1994. It is a shame the access panel is gone.Seen that last night did not know they started using that internal water pump.... what a huge mistake on what was a good V6. It is like nissan hates their customers these days.
I only watched the first 20 minutes, but he said at the beginning of the video that this is only the 3rd one he’s seen.I knew the lack of an access panel was a thing, but I've still yet to find more than a single failure.
I'm not sure where he is finding tons and tons of people having failures on them
He did. At the end of the video he said he found a "ton" of posts and the reason the core was so cheap is because when it goes out it takes out the block.I only watched the first 20 minutes, but he said at the beginning of the video that this is only the 3rd one he’s seen.
Not sure if he backtracked on it later.
I did see that.He did. At the end of the video he said he found a "ton" of posts and the reason the core was so cheap is because when it goes out it takes out the block.
I don't have a dog in the fight but he does point out the 3.8 uses a different water pump. Thus, I'm not sure 4.0 data is applicable....but I'm not an expert on these engines.{snip} Many of the VQ40 engines with the similar design went 300K+ before this was an issue.
It is a different part number but similar design.I don't have a dog in the fight but he does point out the 3.8 uses a different water pump. Thus, I'm not sure 4.0 data is applicable....but I'm not an expert on these engines.
It has weep holes that drain to the exterior side of the block. The video does not really go into much detail of who the end user was but the evidence was there that maintenance was neglected and even if there was indications there was coolant coming out the weep holes it was ignored.In a design like that, how would you know the water pump is on its way out? No weep hole and no warning.
