- Joined
- Aug 3, 2024
- Messages
- 268
I have a 2014 Nissan Frontier with the 4.0L V6 pushing 100K miles. I replace the coolant, radiator hoses and serpentine belt about every 5 years mostly out of habit. Now I'm looking at replacing the small hoses that route coolant to the engine oil cooler located at the filter mount. They're over 10 years old and live in a fairly harsh environment at the bottom front of the engine which is why I'm more concerned about them than the heater hoses (but I haven't forgotten about those either).
What I'd like to know if I might be overthinking this and they'll last a lot longer or is this sort of proactive behavior common around here? See, I'm a retired aircraft mechanic and replacing wear items before they fail is basically in my blood, and this truck is my wife's daily so I want it to be that much more reliable.
I'd just like to hear the $.02 from the masses. I'll likely replace them regardless as it looks easy enough and a set of OEM hoses will only set me back about $40, but I like to get the input of others regardless, especially if they had an actual failure at some point. Thanks as always.
