Gents,
---> UOA on tinypic: http://i39.tinypic.com/xdavro.jpg
I need some advice from the quorum. Took my car to the dealer after this UOA, and their response was, in a nutshell, "don't see/hear anything wrong...so see how it goes". Yeah. Anyhow, comments from Blackstone as follows:
Originally Posted By: Blackstone Labs
"Something has happened in the last 6 months that has affected your engine's wear. Iron, from steel parts like bearings, cylinders, rotating shafts, or the valve train, significantly increased, indicating excess wear and the possibility of a mechanical problem. Lead, from bearings, increased ten-fold. Silicon is dropping more slowly than normal, so check the air filter. It may be too dirty for continued use. This oil's viscosity measured in the 5W/20 range. The TBN was 2.6. Track time is hard duty; suggest more frequent oil changes. Try 2,000 miles next time and check back."
My comments: While this oil was in the car, I only took it to the track (road course) once, and the car had the ECU reprogrammed to fiddle with the valvetrain (eek). Otherwise it was uneventful city/suburban driving.
Bold emphasis is theirs.
MI/HR on oil - 4,502 mi
MI/HR on car - 15,341 mi
Sample date - 09/29/09
Oil added - 0 quarts (0 quarts)
aluminum - 7
chromium - 0
iron - 86
copper - 16
lead - 20
tin - 0
molybdenum - 314
nickel - 0
manganese - 2
silver - 0
titanium - 0
potassium - 3
boron - 27
silicon - 25
sodium - 3
calcium - 2048
magnesium - 10
phosphorus - 717
zinc - 824
barium - 0
SUS Viscosity @ 210'F - 53.0
cSt Viscosity @ 100'C - 8.18
Flashpoint in 'F - 385
Fuel % - Antifreeze % - 0.0
Water % - 0.0
Insolubles % - 0.3
TBN - 2.6
Links to Previous UOAs threads for this car (didn't post 3rd fill):
http://www.bobistheoilguy.com/forums/ubb...034#Post1209034
http://www.bobistheoilguy.com/forums/ubb...172#Post1209172
aluminum - 7
chromium - 0
iron - 86
copper - 16
lead - 20
tin - 0
molybdenum - 314
nickel - 0
manganese - 2
silver - 0
titanium - 0
potassium - 3
boron - 27
silicon - 25
sodium - 3
calcium - 2048
magnesium - 10
phosphorus - 717
zinc - 824
barium - 0
Water % - 0.0
Insolubles % - 0.3
TBN - 2.6
