NGK Ruthenium Spark Plugs
Originally Posted by The_Nuke
Originally Posted by Dave_Mark
I know a person who purchased spark plugs from an AutoZone. The spark plugs were returned by a previous customer but were "new." The previous customer actually painted some old spark plugs from a different vehicle silver and stuck them in the box.
This person who purchased the "new" spark plugs ended up destroying their engine. The plugs were too long.
Why did the person use the silver-painted plugs in his engine instead of returning them for actual new plugs?
Probably because the next person probably thought he bought new plugs
They were painted pretty well and all the plugs purchased were painted, so none of them really stuck out. What can you say: weekend mechanic slaps something into his car without much thought. A "real" mechanic might have noticed the slightly dull silver finish instead of shiny nickel plating.
A "real" weekend mechanic would have compared new to old and caught the different length. I've NEVER "slapped" new plugs into a vehicle, even as a teenager. How do you know the parts guy gave you the right parts? Everyone is capable of making mistakes, even the people who work in factories and pack the boxes.
I just did the plugs on our GS 350, which should be the same or similar engine. 72k miles on it. The original 3 electrode (not really, it's weird) denso came out and I installed the exact same back in. Denso was $8.99 per and rutheniums were $19.
Observations: the old plugs had wildly varying gaps. Some looked nearly new and others were 2-3 times the gap. I've never seen iridiums worm as much as these were at 70k. What's going on in these 3.5s? The idle was immediately smoother and acceleration also seemed a little less rowdy.
I really don't understand the denso design. There are three anodes (cathode is center) but only one has the tiny gap along with the iridium pellet. It, like a standard plug, is in line with the axis of the anode. The other 2 are off to the side, kind of like the multi-electrode bosch designs, except they are far away and don't have any iridium pellets on them. It is very weird and I don't see how they do anything. There was no wear on the ones that came out.
I hope mine gets an uptick in mileage- we bought this as a 3rd car but it gets worse mpg that my f150, except on the interstate. Sort of silly to drive the truck for better mpg. It is, however, a beautiful and highly refined vehicle to drive.
M
That is a great point ^^^^^^
Always compare "new" to old parts... You just never know what happened prior to you getting the parts.
My Tacoma uses copper denso or ngk plugs. 30K intervals. Easy to change. I stick to manufactures recommendations. Don’t try to reinvent the wheel when it comes to plugs.
I'm trying to figure out what exactly makes Ruthenium better than Iridium.
Ruthenium has less density, less thermal conductivity, less corrosion resistance, a lower melting point, and higher electrical resistivity.
I'm not a chemist, but it seems like it should be less desirable than iridium as a spark plug electrode material.
What is the comparative advantage of Ru vs Ir?
Ruthenium costs less than iridium, for ngk to buy.
That may be true when looking at them in their pure form but what happens when you use it in a mix with other metals to form an alloy?
It is also interesting that they make two electrode designs, one is specifically designed for forced induction engines which is a big deal with so many smaller turbo engines being used today.
https://www.aa1car.com/library/ruthenium_spark_plugs.htm
I no longer trust Amazon or eBay. It's sad, because I used to like them. Now they re-sell items that were previously sold, opened and returned, as new. Once upon a time stores would label such items as "open box" and re-sell them with a discount, so at least you knew what you were getting and they were being honest. Not anymore. Now they outright lie. Nothing stopping unscrupulous people from returning a broken or defective item they previously purchased there or elsewhere, or returning a used item, or returning a counterfeit item.
I'm in Canada and I would only ever buy spark plugs in person from Canadian Tire or Partsource in a sealed blister pack, not a cardboard box.
I have not changed a spark plug in a car in over 20 years. I think the dealer changed them once in a 1991 Infiniti Q45 I owned. Admittedly, during that period, I also owned several diesel vehicles.
But, if you have a part that the manufacturer put in the car at the factory, such as a spark plug, and it gave satisfactory service for 100,000 miles, why would you want to replace it with something different if the original part were still available?
As for eBay, the only thing I will buy there is razor blades.
I changed out my original Iridium plugs in my Chevy 6.0 at 180,000 miles with another set of AC Delco Iridiums. (look, I forgot , OK? ).
The threads were a bit rusty and they came out with a puckering mighty squeal.
If I keep the Burb another few years, it will be time to change again. I wonder how many people have changed Iridiums twice on the same vehicle at over 100,000 miles each. :D
Not over 100k per set, but my 07 Mazda3 specs 75k plug changes (iridium), and at 145k I just changed them again recently. Both times they had tons of life left and looked great. Changed them anyway. I'm only 75k-ish away from change #3! 😆
Used Ruthenium NGKs this go around. Previously put them in the wife's car, and liked them.
Try different gas, ruthenium plugs are not worse than Iridium in any way. I got ruthenium plugs in Forte and they run fine, didn't notice much difference compared to Iridium ones.
its likely the coils are weak because they were having to generate so much potential for so long on the old plugs. Coils typically don't go out on their own. They go out due to external factors.
I've been using ruthenium ngks from rockauto for about 3000 miles now, and all i have to say is they must make sparks because the car still runs.
I’ve been using NGK ruthenium’s for about 35k miles now, no issues thus far. If anything, I noticed the gas mileage went up by 1-1.5 mpg post spark plug change at 100k miles.
I got 4 of 8 Denso IT24 plugs used from rockauto. Had obviously been installed, ran for a bit then returned. They made it right but why would a retailer restock returned spark plugs.
