Has anyone used the new NGK Ruthenium HX Plugs here at the forum and if so did you notice any improvements?
We dont stock them at work right now.. However I have seen them online and they are pricey... Just wondering what you all think?
Below is what the NGK Website says.
The Latest Innovation in Precious Metal Spark Plugs.
Modern engines demand more power while using less fuel, shortening the life of traditional iridium and platinum spark plugs. NGK's patented ruthenium technology stands up better to wear to bring maximum durability and performance to your engine.
Designed for every engine.
Ruthenium HX is available in two designs to best maximize the performance of your engine.
DFE (double fine electrode) maximizes ignitability while reducing emissions for low-heat engines. This NGK-patented design is recommended for non-turbo applications.
PSPE® (projected square platinum electrode) provides the best ignitability and service life for high-heat engines. This NGK-patented design is recommended for turbo and supercharged engines.
High ignitability for better cold starts.
Ruthenium HX provides more complete fuel burn than other precious metal spark plugs, resulting in quicker throttle response, smoother idle and better cold starts.
Better durability at high temperatures.
Ruthenium performs better at high temperatures in various driving conditions compared to the leading precious metal spark plugs
More stable under pressure.
Standard combustion tests look for a spark plug's ability to maintain stable performance during combustion and engine operation. When compared to conventional spark plugs, Ruthenium HX remains more stable with less dispersion
