2013 Honda Pilot spark plugs: NGK Ruthenium HX vs NGK Laser Iridium
South Texas
2013 Honda Pilot EX-L w/ approx 54k miles.
I was going to make an order w/ RockAuto for new wipers for our vehicles and figured I would throw some spark plugs in the cart for our Honda Pilot.
I came across the NGK Ruthenium HX plugs, p/n 96358 at $7.66 each.
The OEM plugs are the NGK Laser Iridium p/n 90074 at $11.25 each.
* Can anyone give me any input on these Ruthenium plugs? I was not aware of these new type of plugs, I guess I've been out of the loop.
* Not factoring in the price, is there any benefit to run the NGK Ruthenium plugs over the OEM NGK Laser Iridium plugs?
* Should I change the plug wire/boots at the same time, or just re-use them if they look good?
My plan was to clean the MAF and run some GDI cleaner through the engine, then replace the plugs afterwards.
Thank you in advance for anyone's experience or input on this!
PA
I changed my spark plugs in the Mazda around 70K. They were the usual Asian recommended NGK Laser iridium's but I used NGK Ruthenium's. They are about 5K miles in and appear just fine. At the time they were actually cheaper than the laser iridium's but that's not the case anymore.
AutoMechanic
Site Donor 2023
Roanoke Virginia
I have no experience with Ruthenium but Laser Iridium are excellent plugs from my experience. You can reuse the boots and wires as long as no cracks or anything and as long as they seem to be working fine.
USA
Ruthenium is a good idea on a transverse V6, but nothing wrong with the OE iridium, either. The ruthenium is supposed to last longer, which comes in handy where the job is difficult :)
The original spark plugs are supposed to be good for at least 100k, which is why they cost so much. Even the cheap G-Powers should be able to handle 50k. There are no spark plug wires in your Pilot.
MI
I put Rutheniums in my Patriot, which came OEM with NGK conventional nickel tip (**aka "copper" plugs). No regrets here, and it will be nice to abandon the 30K plug changes.
We have no way to confirm the claim about better ignitability, but the technical discussion we had here claim that fine wire should produce a better quality spark vs. the nickel tip. It's tough to imagine much difference vs. iridium fine wire.
** yes, I know all plugs are copper
SE British Columbia, Canada
You’ll get 100,000 miles out of of the Iridiums easily. The verdict is not out on the Ruthenium’s but more than 100,000 miles. I have not yet seen people reporting back on the Ruthenium’s as they haven’t been around long enough.
Islandvic
South Texas
Thank you for everyone's responses, suggestions and experiences!
Still haven't ordered from Rock Auto yet, probably will this week. Deciding if I'm going to add some other parts to the cart.
PA
Make sure you find a coupon code from the promotion section. Takes 5% off
Alberta
Take 5% off the order as below. I put Rutheniums in the Mazda CX5 a few weeks ago. Runs the same as it did before and they should last longer than the iridium ones.
Code: 16338717953304140
Thank You for Being a RockAuto Customer for over
6 Years!
Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied to shipping, gift certificates, or to an order once it is marked as shipped.
Your code expires on March 28, 2021, 12:00 Midnight CT, so do not wait!
SHOP NOW at https://www.rockauto.com
Share Your Code!
There is no limit on order size or number of orders - use your code on your next order, and share it with your friends and family!​
North Dakota
At only 54K on OE Iridium plugs I wouldn't buy either plug right now if I was you. As others have said 100K EASY and I've seen multiple examples of 150K plus even that look like new.
