Originally Posted By: Robenstein
My Tecumseh flathead powered snow bird thrower came with a Gator brand spark plug and its ready for a replacement plug. The local store has NGK and the Champion EZ start in stock. Is the EZ start work a buck more?
A small engine is the ONLY place I would ever use a Champion plug and then only if I had no other options as another member said above. Worst plugs( name brand )IMO out there. NGK plugs are very good quality and I have had nothing but good luck with them in cars, yard equipment, and marine use. So, of the two listed no question for me it would be the NGK.
FWIW I would also throw out E3 plugs. YOu can get them at AZ, AAP, and others etc... I don't advocate them in vehicles but in small engines they really seem to do a good job and make it easier to start. I have E3 plugs in my snow blower, generator, and lawn mower. The generator and lawn mower were bears to start even with an NGK plug( forget it with the OEM Torch junk they came with ). Starting definitely is improved in them with the E3's.
