Originally Posted by DuckRyder
Originally Posted by Wolf359
Where is that relief value pipe going to? I'm surprised you didn't put a pan underneath the water heater and tie it into the same drain as the relief valve.
Most of the newer ones around here have an alarm and an electronic shut off wired into a float switch in the pan...
You would be surprised (or maybe you wouldn't) at how much water they can spew while someone is at work, and how much damage clean water will do...
I'd say ice maker lines and water heaters are the biggest culprits...
Indeed, my condo had a former owner's claim to waterline slowleak damage (PEX run through crawlspace) ended up a total of $80k to the beam of the kitchen floor. A friend's condo water heater also split open and damage multiple units below him.
