NEW DEALER STOCK, VOLVO TRANSMISSION FLUID - AUTOMATIC TRANSMISSION. A MINERAL OIL SUITABLE FOR AW55-50SN AND AW50-42LE. THE OIL PROVIDES AN EASY GEAR CHANGE AT LOW TEMPERATURES AND OPTIMUM PROTECTION AT HIGH TEMPERATURES.
IMPORTANT: THE OIL IS NOT TESTED OR SPECIFIED UNDER STANDARDS OTHER THAN THOSE INDICATED IN THIS LISTING. IN ORDER TO SPECIFY THE CORRECT OIL FOR THE CAR, ALWAYS CHECK THE OWNER'S MANUAL FOR THE CAR
TECHNICAL DATA:
DENSITY: 870 Kg/ cu M
BASE: MINERAL OIL
LOWEST FLOW POINT: -65.2F
FLASH POINT: 388F
VISCOSITY @ 104F: 40 sq mm/sec
VISCOSITY @ 212F: 7.5 sq mm/sec
VOLVO PART NUMBER 1161540
How do you guys rate this Trans fluid? I thinking about useing this?
TECHNICAL DATA:
BASE: MINERAL OIL
FLASH POINT: 388F
