That would be my choice as well, or figure out how to get it to @clinebarger . With the money saved over the other shop it would be well worth it, and I'm 100% sure the job will be done right.Ford and GM are the only options? That should narrow it down plenty for him, especially if he’s going to take your advice and stay away from any turbos and the coyotes.
You want suggestions? Ram with a 5.7l or a 6.4l. I will say that I am biased though.![]()
That's what I was thinking and wondering about, too. ????Power Train Warranty. 5 years and 60,000 miles?
Ford has a 5 year 60,000 mile power train warranty. Based on your post, the vehicle falls into that category.Well... I'm sure I'm going to open-up a can of worms here. In a nutshell, I am trying to help-out a buddy that owns a 2019 Ford 150 with the 3.5L Twin Turbo and 59k miles.
Last week, he called me for help and pulled-over on the highway because of a high temperature reading. Checked coolant level and there was practically zero coolant left in the recovery tank. We added a full gallon of new coolant and temps got back to normal. He caught it just in time. Not only that, every time he started the truck, he heard a 'knocking sound" (Which was determined today to be cam phasers and timing chain "slap".)
Anyhow... the truck is very well maintained and only has 59k miles. He just came back from a reputable shop and got an estimate of almost $6k to replace and fix the water pump, timing chain and more... He's not happy and asked me what I would do. (I told him I would never have purchased a F150 with the Coyote V-8. Turbos and that boosted engine are a joke for long term.)
Sooooo.... He's looking at another Ford or GMC with two options - V8 or Diesel powered. No interest in any "Turbo" BS... Any suggestions?
I told him I didn't know much about the Diesel choices and was unsure if Ford offered a V-8 in any of their models (2022/2023)?
What stands-out for reliability these days? He tows less than 9,000lbs and needs to know what his best option is. NO TURBO's for him anymore.
Thanks!
HUH? Those are two different engines.I am trying to help-out a buddy that owns a 2019 Ford 150 with the 3.5L Twin Turbo and 59k miles.
JGmazda said:... pulled-over on the highway because of a high temperature reading. Checked coolant level and there was practically zero coolant left in the recovery tank. We added a full gallon of new coolant
The two statements above are contradictory; how is a "well maintained" truck a gallon low on coolant? Any engine that low on coolant had one of two things happen:Anyhow... the truck is very well maintained
This is not unheard of in the 3.5L EB engines. While not "common", it's a known thing. However, this doesn't happen overnight. Every time he started the truck and heard the noise, he was ignoring an obvious problem. I don't believe this truck is as "well maintained" as you're claiming it to be; I think it's been grossly ignored.Not only that, every time he started the truck, he heard a 'knocking sound" (Which was determined today to be cam phasers and timing chain "slap".)
2019 Ford 150 ..... and only has 59k miles.
As has been said, a 4 year old truck with 59k miles SHOULD fall under warranty; he shouldn't have to pay anything.JGmazda said:He just came back from a reputable shop and got an estimate of almost $6k to replace and fix the water pump, timing chain and more...
I think you have your statement mixed up? You meant to say you WOULD have purchased a 5.0L?(I told him I would never have purchased a F150 with the Coyote V-8. Turbos and that boosted engine are a joke for long term.)
I suggest you review your comment; any modern diesel is turbo.Sooooo.... He's looking at another Ford or GMC with two options - V8 or Diesel powered. No interest in any "Turbo" BS... Any suggestions?
Not to be rude, but that much is plainly obvious.I told him I didn't know much about the Diesel choices
5.0L in the F150; 6.8L/7.3L in the SDs.and was unsure if Ford offered a V-8 in any of their models (2022/2023)?
Most any full-size modern truck should handle that just fine. Towing capacities are well stated on the OEM websites.He tows less than 9,000lbs and needs to know what his best option is ...
You're welcome.Thanks!
+1A new diesel with emissions will be more complex and $$$ than any TT engine IMO.
Good points.Should be at a dealer being repaired under the 5/60 powertrain warranty, period. Your buddy should be out nothing here.
Not complicated or hard to figure out what to do, unless there is more to the story or its all a line to get people worked up.
I love this forum sometimes, that's awesomeThe shop is stacking labor.....That's the ONLY way they could get $6,000 for this job!
Guess they're doing 1 bank, Putting it all back together, Then tearing in down again to do the other bank to justify the double labor??
My opinion is.....If you don't like to (Or can't do) engine work, Then don't quote engine work.....Send them elsewhere!
I'll do that job for $2,500 Labor with customer supplied parts (OE Ford ONLY!)
Jeez. I bought a new block from FRPP and built a long block 2V 5.4 that can hold 1200HP for less money than that.The shop told him tonight they cannot even locate a timing chain "Kit/part" due to availability. ??? From what I understand, the 3.5L has a bunch of non-conventional engineering going on which means digging-in and removing quite a bit of stuff to get at everything. $1,900+ in Timing chain parts alone. Labor is like $3,200.
Water pump and thermostat is around $520 (parts) (No labor charge applied as they will be there anyway..) This and a couple other things.. Just shy of $6k...
That's a good statement... I told him his decision is his own, however, buying a new vehicle is expensive and it would depend highly on what he obtain locally and what type of deal is out there. We shall see what he finds....They all break. The Chevy/GMC will too. I'd shop around for another price quote and fix what he has. All he would likely be doing is trading one set of problems for another. A $6k problem sucks but I don't know that spending tens of thousands on a replacement truck is the best solution to that problem.
Good point. He's in construction and does not tow every day, but the times he does tow, he wants the capacity. Good points on the Toyota V8. Thanks"Tows less than 9000lbs."
How often does he tow?
2021 and older Toyota Tundra with MPFI 5.7L V8. Towing capacity iirc about 10200lbs. Newer models are twin turbo V6.
Same reason I bought my Tundra. Didn't want a Eco, DI and/or Turbo.
If I was towing 9000lbs regularly or daily, I would buy a diesel. Otherwise Tundra will do the job if you don't run into payload issues.
Really... Wow..okay... I was wondering if there was a warranty on this. I'll ask him to check it!Ford has a 5 year 60,000 mile power train warranty. Based on your post, the vehicle falls into that category.
