New tools
Fort Worth, Texas
Took advantage of a Buy-One-Get-One deal my Snap-on dealer had going, Buy the Metric flare nut sockets....Get the SAE flare nut sockets for free.
I've wanted these sockets for years, But never came across used ones or a deal on the truck until now, $500 cash for both sets after some negotiation.
[Linked Image]
[Linked Image]
Those are sexy AF... but GULP $500 for 17 sockets? Timesaving tools like those only make sense for those that use them for a living... what's the torque limit on something like that with such a severe cutaway?
Exactly what I was thinking . I would have to use them most every day .
I might use them , might not . Ever .
So , $ 50 is more than I would bay , or $ 25 for the metric & $ 25 for the SAE sets .
I have metric & SAE flare nut wrenches and seldom use them . ( Last time was probably installing a mini split . ) And mine are HF . Think I may have metric flare nut crow's foot for the ratchet ?
As far as a torque limit on the flare nut socket , you could break them loose with a flare nut wrench & then spin them off with the socket ?
Nice! I only have a few of these from Hazet as specialty tools for VW, MB, BMW but they are similar and common metric sizes.
Most if the time a flare crows foot or flare wrench gets it done so that would be a big investment at this point. I can see where you would use them more.
Snap On flare wrench wrenches are the best and I assume their flare sockets are, too. Flare wrenches/sockets are one of those tools that you should spend money on.
That's the only brand new Snap On tool I have ever purchased, a metric flare nut wrench set.
The only flare socket I have is an oxy sensor one, and they do spread on a tight one. I have a taper roller inner race that I slip down over the socket the stop the spread, but that's not going to work ona pipe unless you get the other end off.
I didn't even know something like this existed. I needed something like this for undoing the hydraulic lines from my trucks steering gear last summer and figured I'd have to get a crowfoot version. These look very easy to control and balance into position so they're kept square on the nut. More controlled torque and hopefully fewer broken bolts.
That is a great idea!
I have those in SAE only. Nice tools. Good deal.
Want to be truly horrified? Look at what Snap On 1/4 inch drive flex sockets cost.
Originally Posted by JeffKeryk
He who dies with the most tools wins.
Extra points for Snap-On
You can't take it with you. ; )
for a pro in business snap-on mac + others are worth it, but for average joe too $$$$$$!! i have a very few snap-on wrenches for special applications. i bought a 7/16 box + open wrench years ago $10 craftsman was $3.26, but the smaller size + closer tolerances tightened my header bolts better. that i learned at my friends garage, a professional alignment shop!! its like using Redline oil in a cheap daily driver, good but not needed but its your $$$
Those are very expensive from any big quality name.
The problem is....I don't own any metric flare crows feet. I have a Snap-on SAE set I bought @25 years ago along with some individual SAE open ends over the years. The 1-1/4" crows foot was IIRC over $100 & used it a hand full of times on Accumulator fittings on a obscure GM Incomplete/RV chassis.
Unfortunately.....I had to have Metric & SAE tools sets when I started out in the late 80's as GM dealer tech. I almost envy techs today having to only buy metric tools. Though it IS entertaining to watch one work on a 2002 Express Van with a 5.7L that has a plethora of SAE fasteners
I know you know what I'm talking about Trav.....
[Linked Image]
Your referring to the 1/4" universals?
111TMUSMA, 5.5-15mm.....List for $530.00
106TMUSA, 1/4"-9/16".......List for $286.00
I have a Cornwell set of 1/4" drive SAE universals, I don't remember what they cost. Pictured in the above pic.
I prefer 1/4" Impact wobbles over the universal style, Just as outrageously expensive.....I have a 1/4" to 1/4" adapter, 7mm, 8mm, & 10mm that does what I need. I want the 13mm & 15mm.
[Linked Image]
Originally Posted by JC1
Nice looking sockets. I hope you get good use out of them. Will you be using most sizes?
Probably not, If I didn't get the SAE set BOGO....I would have eventually just bought the metrics as I already had SAE flare crows feet.
Those seem like an art form to make and still have needed strength …
On the down side … you can't mention tools like these if you interviewed at that shop in Florida …
