New tool thread
Dad had a flat tire on his big truck today. Bad valve core. Came all the way off the rim. Got this bottle jack to raise it up. Tried three times to get it aired up and twice it slipped off this jack so dads going to just have the tire guy come do it and pay the $300 but he did tell me I could keep the jack lol. I told him save the $300 and get a 4 ton floor jack and we will bring that and our 3 ton and our large jack stands and try it again. We had it starting to seal then the jack slipped off. Thankfully we were just airing the tire up and not underneath of it. I wouldn’t be underneath of it without a jack stand anyway. I personally would have gotten a bigger bottle jack than this one because the cylinder is only about a couple inches around but that’s just me
View attachment 313358View attachment 313359View attachment 313360
https://www.amazon.com/Bottle-Jack-...=d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM&th=1
They pretty much only come in electrical KO sizes but the Milwaukee "hole saws" meant for an impact driver work surprisingly well. If they ever have the sizes you need I highly recommend.
I have a bunch of their carbide hole saws but nothing small enough and I didn't want to try a twist drill, some of the stuff is 0.020"
You can get step bits that have a max size of 1/2".
I wouldn't think an annular cutter would work to well in a hand drill. I would think it would walk everywhere.
  • Like
Reactions: D60
Stupid question, Spyder mach-blue was gone from lowes for a long time here so I have been using Anchor if you have used it did you notice any difference?
My thought as well. I've got carbide tipped hole saws, but the 1/4" pilot bit provides a measure of concentricity. Most spring loaded ejector pins in annular cutters have a lot of lateral slop, but perhaps it's possible to insert something more rigid and with less slop -- I've honestly never tried an annular cutter in a hand tool because it sounds "wrong"
I almost picked up one of these but didn't have the discretionary funds during BF. Do give us a review after using it.
Posted some early results on monitoring Honda's VCM system on my 2025 Pilot, trying to validate whether Sport drive mode disables VCM. Early testing shows that it does.
This links to the first testing, but was very limited. Graphs included.
This links to my summary after testing at highway speeds.
Maddox harmonic puller kit. $50 at pawn and looks 100% unused. Retail at HF right now is $85
I've got several smaller puller kits just for dampers, but this one looks absurdly comprehensive and at 11:30p on a Saturday night, I like options
Set of Icon ratcheting wrenches to replace a set of Platinum branded ones, Same set, Both made by Kabo.....At least HF will warranty them?? First Icon tool for me.
10R80/10L80 sealing ring installers & resizers along with the drum/snap ring tools from VMS Concepts....A little pricy but I've had great luck with VMS tools for other units.
I've got several smaller puller kits just for dampers, but this one looks absurdly comprehensive and at 11:30p on a Saturday night, I like optionsView attachment 314219.
I have the Performance Tool version, Same manufacturer I believe. It's okay...My dedicated Gen I/II small block Chevy HB installer I had for years decided to give up on me & needed one quick.
  • Like
Reactions: D60
I keep looking at those Icon extra long spline wrenches, but I already have some extra long non-ratcheting and the Astro Nano sockets and long ratchet. I'm wondering if it's worth bothering with the Icons, especially in light of 40% off on Sunday (that's $92 off). And some of you folks aren't so keen on the splines for non-spline fasteners.
So no concerns about spline wrenches on hex fasteners? That has always been a concern so I’ve never gotten any…
I hate 'em. They're marketed as the next great thing but I simply can't stand spline drive. Does it work? Sure, most of the time. Is it better? I'd say absolutely not. It's more likely to try to "ride over" and get stuck on a fastener, and unless you have REALLY good, FULL engagement, it's much more likely to damage fasteners.
The Kabos are actually quite thin and flex easily. This means on stubborn stuff they just deflect. The side button is actually easy to bump.
I wish I could afford (justify, really) the Snappys, but the price is stratospheric.
The middle ground is Matco. Still spline, but a MUCH thicker beam, and more traditional reversing lever on the back. I actually REALLY like my Matcos, but still wish for 12pt -- and I only have the metrics. Every time I need fractional and have to reach for my Carlyle (Kabo) I make sad face. :(
I think someone like HF could make a small fortune if they perfected this space. Everyone either rebadges the Kabos or tool truck stuff is beyond the common man.
We have the technology, it's not hard:
1) thicker beams than Kabo
2) 12 pt
3) reversing lever on back
4) keep the SHORT extended drive on one side, it's awesome for things like reaching into tensioner pulleys
5) I'd like to see metric and fractional, but must admit sales of the latter may be lackluster
6) ICON pricing but not SnapOn pricing $$
I don't think this is too much to ask, and most of it is just combining pieces already in manufacture.
/rant off
2) 12 pt
/rant off
That's pretty much how I feel about them, The offset is the only reason I keep a set handy.
  • Like
Reactions: D60
