I can't seem to get all the spark plugs in finger tight. Two will turn about 12 times until the gasket hits, and the other two I can only turn 2-3 times by hand. I suppose the grooves are crudded up. I was planning on running the old plugs for a little while longer until everything gets cleaned out. Should I go ahead and install the new plugs after the soak or try to run the old plugs for a few more miles? Any tips for getting the old plugs back in if that's even a good idea?
