New Subaru Engine for 2011 Forester
N.H, U.S.A.
Supposedly first all new archetecture in 20 years! It's now DOHC with dual timing chains (rather than belts) and VVT. They also increased the stroke almost a 1/2 inch, finally fixing the silly way-oversquare configuration. I agree with the bore /stroke change for a passenger car, unsure about DOHC and the chains. Would have preferred SOHC with roller followers on a 3 or 4V head still with toothed belt cam drive for simplicity.
My Question:
Anyone here test drive a Foz with this new engine and would you care to share your impressions?
My Mom drove one when she was car shopping. I rode along. It felt pretty smooth and carlike for sure. Didn't blow me away but it wasn't weird or slow by any means.
Yep.Still a waterboxer, Not that that's anything good. 2 heads, 2 T-chains, 2 exhaust headers ... on a 4 cyl. Worked well in the A/C beetle in the rear or for any rear engine car needing a pancake engine - not required in the Forester or impreza. Anyway the subaru 2.5 liter was very poor architecture (for normal output variants) and needed revamping. I wonder if they went to a shared crankpin (3 throws/4 mains) as I would design it (and consider proper and elegant).
I had a 2001 Outback with the H6. I remember thinking that if the timing chain / tensioner ever needed service, there was going to be about 2 hours of labour just to remove the 65 bolts keeping the timing chain cover on...lol.
"New", but not much improved:
"The new 2.5-liter engine displaces 41 cc more than before and features dual overhead camshafts in place of an SOHC setup. It still makes 170 hp but gains 4 lb-ft of torque, for a total of 174."
MPG increased by +1. You'd think more output would come with the major changes?
I'd bet that the torque and horsepower charts show a much more substantial difference. Peak numbers tell you very little about the whole.
Torque? Horsepower? Fuel economy? Who cares? This is probably the first engine made with love.
Thank you Subaru for that horrible marketing campaign.
Clark
Aside from their AWD system, I don't see any reason why one should consider a NA Subaru over its competition. Their MPG and performance are not class-leading, and their technology is needlessly complex.
3 throws and 4 mains on a 2.5 litre 4 ?
That's pretty innovative
ROFL!
For me, they are one of the few car companies that offer a wagon.
We're also bemoaning the dearth of wagons available and giving Subaru a good, hard look.
I will say that I have a big soft spot for Subaru, as I was amazingly lucky enough to have an Impreza as a rental car which was most likely the only reason why I was able to escape from Maryland during Snowpacalypse February 2010. No, it wasn't particularly efficient, class-leading in technology or quick - but it was an amazing all-rounder that did everything well.
I would like to know what technology isn't needlessly complex?
As far as AWD systems do theirs in manual transmission car is surprisingly simple.
Originally Posted By: Tornado Red
My sister bought a 2011 Forester, and got a surprisingly good deal for it. But I haven't driven it yet, or even ridden in it. It's big though, inside and out. When did Suburus get so big?
When our bottem's did
ROFL!
Really?
I dont see the humor, smelly pants.
Draw it. A Shared center crankpin with 2 phased throws at each end requiring 4 main bearings. Engine is still in primary balance. Recall this is just two flat twos attached at the spine and splayed 180deg.
Subarus are not needlessly complex compared to transverse mounted drivetrain designs - Unless you might want instead part-time AWD with pancake electric drive (or hydraulic) for the rear.
