Originally Posted By: Hokiefyd
Originally Posted By: friendly_jacek
Originally Posted By: The Critic
I've aligned this car at least 5 times, tried 3 different brands/model tires and have verified that the suspension is perfect as-is. Granted, the straightline stability was best when I had a grippy set of Michelin Primacy MXV4, but the straightline stability of this car is just lousy compared to most other cars in its class.
Something is not right here. What tire pressure do you use? There should be a differential in pressure between front and rear for best traction. Even though I have not noticed it with mine pumped equally at 40-42 psi.
Additionally, just because it's "aligned" doesn't mean the actual alignment is optimal for handling. There is usually a pretty wide allowable range, and moving within that allowable range can make a huge difference in how the vehicle drives.
For example, if the car wanders on the road, front toe should be examined. It sounds like it's too neutral or even toed out. Toe in really adds response to a car's steering, though at the expense of tire wear.
Its just the way this car is. I have it aligned to max negative camber (-1 deg) and a preferred toe setting of 0.10. The wandering is not dangerous, but it is def worse than a larger car. I would say its just slightly below average for the segment.
