Bit of an unusual race motor. Car started as a 1986 Porsche 944 turbo. These come standard with a 4 cylinder 2.5lt single cam 8v and made 250bhp in the later models. Car has been developed into a pretty highly developed Time Attack / Race car. The motor is now 3.2ltr 16v with a forged internals, solid tappets, EFR 9180 turbo. Last time it went to the dyno it made 618whp @ 16psi which is pretty promising. However the block cracked causing an engine fire and I had to source a new block and decided to go with Darton MiD sleeves. They provided a custom copper head gasket and I sourced some hard to get big studs. The head is clamped down 120lbs. The studs were a late addition. When they installed these they expected to have to do a re hone of the cylinders. But they stayed perfectly round which shows the integrity of these sleeves. My concern is with variance in expansion rates but these guys come highly recommended and that's what they suggested using when we sent them the new block etc.
The machinist who installed the sleeves and repaired the head suggested the following:
"Run with JOE GIBBS BR30 or BR40 Break-In oil ONLY on dyno until rings are bedded in. Dump oil, cut oil filter and check.
Run a mineral oil for first 1000km then service and use recommended weighted oil (refer to engine build sheet for bearing clearances and Joe Gibbs oil recommendations"
He then recommended one of the XP6 variants and sent a oil spec sheet to choose from. (Attached) The motor is an Alu block now with ductile iron sleeves. Custom CP pistons and Carrillo rods. I was a little unsure which oil to pick so I contacted the company. This is what they replied:
"I chose the GP-1 15W-40 for a couple of reasons. The 15W-40 is a better fit for your main bearing clearance, your front and rear bearings were a bit tighter than the rest, but I would recommend going to the heavy side in line with the centre mains.
I did not consider the XP for your application because the XP has very little detergent and virtually no corrosion protection package. XPs are formulated for applications that are disassembled and inspected after every event."
I also managed to communicate with Lake Speed (that oil guy) who recommended the GP-1 20w/50.
I've also attached the engine build specs. As to the tighter clearances on 1 & 5 this is what the machinist replied:
"The variation in main clearance is due to bearing shell wall thickness variants. The tighter clearance on #1 & #5 is not a concern as it is still sufficient clearance and well within manufacture specifications and .0005" larger than minimum."
Sorry for long winded thread. The car is due to the dyno in the next few weeks and we're just deciding on the oil. I'm sure there are some highly experienced people inside these 4 walls who can offer some expert advice.
Thanks in advance.
Thanks in advance.
