New plug Briggs & Stratton Polar Force 420cc
Boston / Sunapee NH
Had to change the plug on the B&S 420cc today. The stock plug was a Champion RC12YC. Replacement is an NGK BKR5ES. Not sure if that is an exact replacement? Starts instantly so good enough. Easy job.
Two 9mm bolts hold the plastic cover on. Use two screwdrivers to pry up the choke. Caveat: the choke is mounted to a plastic shaft.
