- Joined
- Apr 13, 2025
- Messages
- 663
Hello
I am replacing the original piston in my 3.8L Dodge Caravan engine and there is a difference in weight between the old and new.
The original wrist pin weighs 134 g
The new wrist pin weighs 140 g
The Original piston with wrist pin weighed 568 grams total
The New piston and wrist pin weighs 585 grams
For a total difference of 17 grams heavier for the new replacement piston. I read that 10 grams is the maximum difference you should have between piston assembly weights on an engine. Being that this is a relatively low RPM engine (4200rpm max) it may not matter?
I am inclined to carefully remove at least 10 grams from the new piston to bring them closer.
I will begin by drilling the hole seen in the original piston in the new piston shown at the yellow arrow.
Then remove weight from the areas indicated by the red arrow until the weights match.
2 Quarters weigh 11 grams.
My options are
1). Do Nothing, ignore the difference
2). Modify the piston to reduce the weight
3). Get a lighter wrist pin or have the new wrist pin machined to lose weight.
4). Get the wrist pin machined AND reduce the piston weight
5). Use the Old wrist pin to reduce total mass by 6 grams (Both wrist pins measure precisely 0.9000in) (I will likely do this)
Opinions?
PS - Does that hole in original piston serve a purpose?
My options are
Opinions?
