New Motul 0w20 double ester
quote:
Originally posted by yannis:
quote:
Originally posted by buster:
Also, all oils that claim to be 100% ester are not in that some carrier is used...PAO/Group II/III etc.
Are you saying that in ester oils , PAO is added as an additive carrier
? I thought we had cleared it up that PAO's biggest problem is additive solubility. Don't you remember Mobil 1 using a small amount of dino as an additive carrier?
I think Buster just misspoke. What he meant is that ester based oils still have a significant amount of other non-ester base oils in the blend. I don't think any current motor oil sold at retail has over a 50% ester content, even Redline.
The possible exception would be Fuch's Titan GT-1 0w20, which uses some pretty unique and exotic esters, the content of which may be 100% in that particular formula.
The few people on this board who are in a position to genuinely know (and are identifiable as such) have all given their 'estimates' of Red Line's ester content, and it's all over 50%, with most being over 70%.
quote:
And just who would those people be?
The ones I believe are in the best position to know have said no more than 50%.
quote:
Originally posted by boxcartommie22:
everyone else has no proof either its all speculation!!!
Now there's a rejoinder that slays all doubt as to the veracity of your position.
Redline is a high percentage ester oil composed of the best esters in the industry.
And yes, analysis labs do have a problem analyzing high ester oils for both oxidation and tbn. Most ester base oils start out with a tbn of 2.0.
quote:
Also, doesn't higher oil pressure create more engine wear? Maybe that's why Mobil keeps theirs low.
Oils are only part of the oil flow/pressure equation. High oil pressures do not necessarily equate to good oil flow and engine protection.
Better oil flow lowers engine wear. High oil pressure is caused by restrictions in the engine and filter and by too high a viscosity of oil.
Too low a pressure is caused by too thin an oil and large clearances in worn engines. Redline oils have a starting oil viscosity greater than Mobil 1's.
Time will tell if Redline is really mom and apple pie.
[ July 06, 2003, 08:15 PM: Message edited by: MolaKule ]
Posts: 8586 | From: Midwest | Registered: Jun 2002 | IP: Logged |
Leo
Member
Member # 1380
posted July 06, 2003 19:12
I dunno, I have seem to lost faith in Redline Products. From reading other websites i've come accross I have read _numerous_ reports about;
-MTL/MT90 causing premature synchro wear. Maybe it sacrifices the synchros for good shifting?
-Water Wetter sludging up coolant reservoir bottles. I wonder what the rest of the cooling system would be like.
-Their oils dont produce enough good used oil analysis. Some just seem to be lucky while others are very ordinary.
Is Redline really all they are cracked up to be? Seems that their SI-1 is the only thing I havent heard numerous bad reports about! I think I'll be sticking to M1. Its not the most exotic oil, but you cant go wrong with it...
Posts: 570 | From: Adelaide, Australia | Registered: Apr 2003 | IP: Logged |
JohnBrowning
Member
Member # 1417
posted July 06, 2003 19:48
LEO I belive that you have read all of those things. I question the source of information though. It has been my experinces that shade tree tuners always look for a scape goat to make up for their mechanical failures. I see it all the time in amature import raceing. Their is a lot to be said for self actulization! I have used all of redlines products at one time or another. Their is no way that water wetter if used properly could cause any sludgeing!I ran it year round for 3 years with no sludgeing or corrison. I use MTL in C5 corvettes and have not seen any problems!! I also use it in old corvettes that origanaly shiped with Whale Oil in their Muncie manual transmissions. Their is nothing that would convince me that MTL ate a syncro! I am not aware of any other GL4 compliant fully synthetic lube. Last I checked synchremesh was semisynthetic. No oil blender with their name on the bottle is going to misrate a fluid and open up the floodgates to litagation and class action suites.
Smokey Yunick has also used a Polyol based oil and said similar things. The parts look as though they have never touched. SMokey would not name the brand of oil. The only domestic polyol based oil I am aware of is Redline.
Posts: 5127 | From: USA | Registered: May 2003 | IP: Logged |
Pablo
Amsoil Sponsor
Member # 512
posted July 06, 2003 20:56
John Browning wrote:
By polyol, I assume you mean PAO or polyalphaolefin.....and all this time I thought that infamous (low -sic) price of Redline was because of the ester base...and that Amsoil and M1 are PAO based....hmmm....
Posts: 14679 | From: Duvall | Registered: Oct 2002 | IP: Logged |
MolaKule
Specialty Formulations
Member # 59
posted July 06, 2003 21:24
Redline uses a majority of PE and Di-PE polyol esters (current jet engine lubes).
PAO's are not polyol esters. PAO's are synthesized hydrocarbons derived from and polymerized from petroleum gasses, such as ethylene and other gasses.
Amsoil uses PAO's and TMP polyol esters at last count.
NEO, and a few other companies, still use di-esters as well.
MolaKule
Member # 59
posted July 06, 2003 21:26
Leo,
If you have lost faith in Redline and don't want to pay the price, then don't use the ******* stuff.
However, I think your information, which you have not sourced, is incorrect.
[ July 06, 2003, 11:50 PM: Message edited by: MolaKule ]
Pablo
Amsoil Sponsor
Member # 512
posted July 06, 2003 21:57
Molacule - that's why I like the full name used or a proper ancronym - not just a shortened common term.
As far as Redline - the few used oil analysis have indeed not been outstanding. Funny that some people say Amsoil is overpriced....but defend Redline. I tend to think Redline gear oils are nicely priced, but the motor oils are WAY too expensive.
mf150
Member
Member # 1362
posted July 06, 2003 22:56
I swear by Red Line products. I'll take a bottle of Red Line over any other oil on the market today. I have had nothing but good experiences, and recently my engine was torn down (headgasket leak), the pistons, cylinders and all lubed parts looked **** and span. Th eengine was completely clean, so clean I could eat off of it.
I run 10w30 in an 01 F-150 at 5,000 mile intervals.
I'll have words with anyone that tries to tell me that Red Line is inferior to any other oil.
Posts: 450 | From: The Bay Area | Registered: Apr 2003 | IP: Logged |
sprintman
Member
Member # 4
posted July 07, 2003 00:07
Pable I can't agree no outstanding Redline used oil analysis (they are here somewhere a 5W30 and a 5W40 are two that I remember) BUT I agree gear oil excellent/well priced but engine oil just too expensive here **28 US quart for non racing use.
Posts: 4368 | From: Canberra ACT Australia | Registered: May 2002 | IP: Logged |
sprintman
Member
Member # 4
posted July 07, 2003 00:12
Pable I can't agree no outstanding Redline used oil analysis (they are here somewhere a 5W30 and a 5W40 are two that I remember) BUT I agree gear oil is excellent & well priced but engine oil just too expensive here IMO (**28 US quart) for non racing use.
Shannow
Member
Member # 702
posted July 07, 2003 02:10
quote:
JMB, the oil that Smokey used at Indy was "Allproof", whatever that ended up being in today's parlence.
Posts: 4917 | From: Lithgow, Australia | Registered: Dec 2002 | IP: Logged |
Patman
Administrator
Member # 6
posted July 07, 2003 02:50
I know I've posted this link a lot, and I know it's just one used oil analysis, but it's still the best used oil analysis on here, and it's in a sludge monster Toyota no less!
Redline 5w30:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000340
Posts: 14315 | From: Mississauga, Ontario | Registered: May 2002 | IP: Logged |
Leo
Member
Member # 1380
posted July 07, 2003 03:35
I am not baggin Redline straight out, but I believe there is no clear cut answer whether they truely are better than the competition in your average car. Sure on paper they seem the best, but good specs dont neccesarily mean good results. I believe RL really show their colours in hard driven applications, like my car which produces 150hp/L, not your average grocery hauler/highway cruiser.
Molakule, The reason I didnt not source my comments is because we're not allowed to post URLs outside this website. And I know what I read, so dont say what I read was incorrect. If you want the URLs, then PM me, np!
Btw, I dont want to start an argument over RL vs everyone else, just posting my opinion. Nevertheless I still wouldnt mind giving their oils a shot! Just thinking twice about Water Wetter etc.
Dr. T
Member
Member # 29
posted July 07, 2003 07:19
2 questions:
1. Does anyone know of a European-sourced/manufactured Polyol ester based oil? ie. Euro. equiv. of RL?
2. Where's the best priced Redline in Toronto??
Posts: 2392 | Registered: May 2002 | IP: Logged |
Patman
Administrator
Member # 6
posted July 07, 2003 08:11
quote:
Originally posted by Dr. T:
2 questions:
Check your PMs.
Bror Jace
Member
Member # 20
posted July 07, 2003 08:25
I think JohnBrowning is correct. People who use Red Line are likely to run their car(s) the hardest. They are not a fair sample population. And in those cases even seemingly “mediocre” test results are an accomplishment. And having said that, we’ve seen some really good Red Line used oil analysis results here as well, that Toyota Sienna Patman references being the best example to date ... possibly the best used oil analysis on this board.
As for Water Wetter, I ran this in my Honda Civic with the same coolant for 6 YEARS. When I had the timing belt (& water pump) changed, the was coolant drained and it still looked brand new. If others are getting sludge in their coolant bottles, it’s from a leaky headgasket or some other problem, not the Water Wetter. Of course, I don’t have any evidence that it was doing anything good in my car, I just bought a bottle and split it between several small-capacity cooling systems as a preventative.
As for MTL, Bogatyr and I have used this in Integra and Civic transmissions for over a half million miles combined. No problems with any of the transmissions … even as they approached 200,000 miles. The elimination of cold-weather graunch alone has to reduce some of the wear the transmission would normally be experiencing with a factory fluid. The Civic Coupe I just sold still shifted like brand new at 100,000 miles and I shifted like it was nobody’s business every d@mn day I drove it. Based on my experience with the Hondas, I’ll be using a mixture of MTL and MT-90 in my ‘03 Nissan Sentra’s 6-speed. It calls for some mysterious 75W85 oil and can’t think of a better choice than a blend of the Red Line fluids (70W80 MTL and 75W90 MT-90).
Leo, I’m guessing what you’ve read about MTL comes from “Mista Bone,” a well known Honda tuner on the use.net forums. I think he’s a very knowledgeable guy but kids who abuse their cars bring them to him. He knocks them apart and finds torn up transmissions … and blames the MTL many are using. He’s been knocking the stuff for years and I think it’s either a habit he’s unwilling to break or it’s something personal. His latest take is that the Red Line transmission fluids dissolve some sort of plastic seal in the RSX transmission. I can’t say much about this … but Honda should only put oil-resistant seals in their boxes and if something gets dissolved when using a common aftermarket fluid, it’s the manufacturer’s fault. If I had an RSX, I’d use MTL in it based on my decade of previous positive experience with it in Hondas/Acuras.
I used Red Line engine oils in my Civic over a year ago but a coolant leak (verified) skewed the results a bit. I will be switching to Schaffer Supreme later this summer at around 7,000 miles (3rd change) and will start doing used oil analysis. Next year I will give Red Line another try, hopefully a few runs in a row, ~6,000 miles each.
For you folks outside the United States who think that Red Line is dreadfully overpriced, you might be right ... but even then it’s probably a distributor and/or tax issue and not Red Line’s fault directly. Even though I like their products a great deal, I doubt I’d pay over $8 per quart for anything other than their gear oils. But fortunately, I live the United States and at $8 per quart, it might only cost me an extra $20-30 per year to run Red Line in my engine … which is peanuts compared to the overall cost of operating a car for the same period of time.
--- Bror Jace
Posts: 3549 | From: Saratoga, NY | Registered: May 2002 | IP: Logged |
Those quotes tell me nothing about the % of Esters RL uses. At most, it's been said it contains 65%. It is NOT 100% ester based. You quoted people's opinion of RL. Considering additives can make up 10% of the oil, RL could use 50% and that would be the primary basestock leaving the PAO to be about 40%.
Funny I do not see the Redline Technical Manager (who I know) posting here on what is in his product so I guess there are a lot of psychics on this board.
bruce
i agree bruce because the info given to me several times by tech service is that redline has some pao in the oils not very much..the base oil is all poe
i spoke to dave at redline again for the millionth time and also a blender. he said that all redline oils are pure group 5 it is not a group 4/5 oil.. the base stock is pure poe..so you can going on and disagree whatever you like and i feel you all are totally wrong...also, for your info, engineering said and emailed me tech sheets that motul chrono 300v oils are pure double ester no pao at all!!
i beleive redline what they have consistantly informed me throughout the years..i believe since they worked there they should be able to say and know what their oils are..their transmission fluid is also a pure esters...this should be closed..
