You cant depend on WM website pictures, these might be older images and new label is coming
I can walk in the store …You cant depend on WM website pictures, these might be older images and new label is coming
Since PDS was updated only a week ago, I expect several weeks or even months before updated formula with new label.I can walk in the store …
The two I just bought online have D1 labels …
How many of you worried about it have a GM ?
Buster does and I do … but he’s already used at least two boutiques in it …
There will likely be a lot of adjusting going on. For all brands.I know that prior PDS had it dexos gen3 approved, but with the revised PDS its gone. Did they drop dexos gen3 in the new formula? If its true, this is total BS!
Stand by on this channel for lots changeSince PDS was updated only a week ago, I expect several weeks or even months before updated formula with new label.
I dont really need dexos, but it was nice, now PAO and Dexos certification is gone, not impressed with Mobil 1
And 6 months from now … those who mocked others LoLThere will likely be a lot of adjusting going on. For all brands.
“Meets the requirements of” will be common …And 6 months from now … those who mocked others LoL
They can only move fast when it helps GM - like the 0W-40 rapid fire approvals …GM probably wont budge on the license since they moved from GTL to II+
Makes sense, the cheaper alternatives probably do not meet dexos. Mobil 1 Advanced Clean is on its way becoming another failed product, just like Mobil 1 Annual Protection that was discontinuedGM probably wont budge on the license since they moved from GTL to II+
Those dots don’t even connect … One was very expensive from the beginning at 70% PAO - one just got hit by the Iran conflict …Makes sense, the cheaper alternatives probably do not meet dexos. Mobil 1 Advanced Clean is on its way becoming another failed product, just like Mobil 1 Annual Protection that was discontinued
Different products, but will be both doomed.Those dots don’t even connect … One was very expensive from the beginning at 70% PAO - one just got hit by the Iran conflict …
Another point: two easy things to spot on the SDS are PAO and GTL … not so much for the many others …There will likely be a lot of adjusting going on. For all brands.
XOM will be fine …Different products, but will be both doomed.
I am not worried about XOM, I dont have brand loyalty.XOM will be fine …
Better hide and watch those who can’t make base stocks …
Seems a more common topic would be Pennzoil with Pearl not shining anymore …As time progresses you may see many oil companies ,say cheapen their products due to inflation and the availability of base oils/quality, look for just barely meeting specs or elimination of some ratings. as said before ,,Stock Up Now. the cost of engine oil amoung related products are destined to rise by a fairly large margin, also due to greedy profit margins.
They must be relieved - but Shell has way bigger problemsI am not worried about XOM, I dont have brand loyalty.
Valvoline Restore and Protect is more expensive and also doesn't meet Dexos, so?Makes sense, the cheaper alternatives probably do not meet dexos. Mobil 1 Advanced Clean is on its way becoming another failed product, just like Mobil 1 Annual Protection that was discontinued
