What were your change intervals?The main thing is be sure the engine has oil and is changed on a regular basis. I ran an '88 Ford Escort 1.9L to 518K miles over 20+ years on whatever conventional oil that happened to be on sale. The engine was still running with compression numbers 145-155 PSI across all cylinders when I retired the car for other reasons. Sometimes it was a major brand other times it was store branded oil.
It's a 6.2 gasser.Keep in mind that your truck needs 13.3 quarts on each oil change.
Page 427… 6.2 gasserIt's a 6.2 gasser.
It looks like 8 quarts for the oil and filter change. 13.3 is the cooling system. Funnny, there's no mention of the differential in the capacities chart.Page 427… 6.2 gasser
Thanks…It looks like 8 quarts for the oil and filter change. 13.3 is the cooling system. Funnny, there's no mention of the differential in the capacities chart.
In my opinion, the front and rear diffs come under filled from the factory. Same for the transfer case. Dexos 1 gen 3 is the latest and greatest. GM allows gen 3 to be sold in gen 2 labeled containers for now.Thanks…
