A year or so ago, I moved and have been slowly working on trying to find a more local indy mechanic to work on my vehicles. I do a lot on them myself, but every now and then need some more skilled help or I don't have the time.
It's plug replacement time in my '08 Nissan Frontier with the 4.0 V6. I don't have the time, so I figured I'd get some quotes.
Nissan dealer in town here was $195, out the door.
Called a smaller local place I've been driving by and heard good things about. Plugs came in at $240. But they are also recommending replacing the coil covers ($20 apiece) and the manifold gasket since it has to come off.
Other than the $45 difference on the plugs, I’m curious about the coil cover recommendation. Would you consider the coil cover replacement a wise suggestion? I can understand the desire to replace the gasket while it’s off.
I’ve never worked with this shop, so I figure this could be a good test to see if this is a place I should go to (or not).
