- Joined
- Sep 26, 2010
- Messages
- 9,791
I installed a new set of Kanati Trail Hogs AT-4 in 315/70/17 replacing Falken Wildpeak M/T in 285/70/17. Picked them up from PriorityTire.com for $1,200 for a set of 5 including demounting the Falken's and mounting/balancing the Kanati's.
They are (more or less) Goodyear Duratrac tread design and are 3 peak rated for snow. They also weigh exactly 4 pounds more than the Falkens--84.4 versus 88.4 (mounted weight for both). Considering I went up a size as well as changed from load range C to load range E, the weight difference is minimal and should not be noticeable. I need to use my Tazer Mini and tweak the tire size and pressures and I will probably kill ESS while I am in there.
Very happy with the look and ride so far!
