New information on PZ Ultra composition
Originally Posted By: qship1996
Sure makes the Redline oil I get for 8 bucks a quart look like an absolute bargain!
Where can we get Redline for $8 a quart? I was getting ready to buy some off their site, but it's $11 there.
Originally Posted By: Art_Vandelay
Originally Posted By: buster
Did you read the part where the Shell chemist said Grp III's have better solvency?
He was speaking about financial solvency.
The more Group III Shell can perpetrate, as an ultimate synthetic, the more solvent the company will be.
lol...good one!
Dont kid yourself....its all about saving $$$$ and convincing consumers it is as good as real synthetic basestocks!
Exactly! Coming from a elec. engineer who used to work for a major consumers product company, this is SO TRUE! At the end of the day, it's all about $$$ for the company. I can name soooo many products that are on the shelf at stores with the "New & Improved" tag, but it's actually worse than the original product.
At the end of the day it's the FINAL performance that counts, including OEM and industry specifications. Whether you use Grp III/IV/V base oils, you can make a good or bad oil. It's up to the chemists and what they are shooting for. $$ is obviously a variable. There are many ways to add solvency to an oil.
Theoretically, a full ester/pao based oil should be superior, but it's all relative to what you are trying to achieve. You also have to consider the additive system. It's all about taking many complex components and making a final product. How you get there isn't necessarily that important as long as the end result is what you want.
Cost obviously will always be a factor. Grp III's are less expensive. PAO's are being used more as a correction fluid. Various esters and modern additives are used for increased solvency, wear protection etc.
Redline is a great oil, but unless you are seeing engine/oil temps above 500F, it's overkill. So in some instances and environments, there are better cost effective choices. Just because Redline uses an ester base oil doesn't mean it's superior in all cases.
+2 Please do tell. I'd like to find some RL for $8.
Ultra may be a good oil but a 4k/4Mo. recommended OCI for almost $6 a quart? Won't any SL or SM oil do the same thing at that Ultra-low OCI? As others have mentioned, it will likely go well beyond the 4/4 interval but that would be going beyond the oil manufacturers own recommendations. It appears that Amsoil, Redline and others that sell oil for ~$6-$12 a quart, yet recommend a much longer OCI, are a much better value. For the average consumer that still does between 3/3-5/5 OCI intervals, maybe the Ultra will give them a warm-fuzzy feeling, but are they really getting anything extra for their money beyond the other group III products that sell for $4 a quart? If Pennzoil would have offered a warranty that allowed, say, a 12/12 interval, they could have really hit a home run with this product - provided it could handle a 12/12 interval.
I'm surprised at how many people "know" it was all hype, and we have yet to see any real world performance?
Perhaps some of you guys should be on Montel Williams....
Where is "Ferndog"? He was the Pennzoil guy here @ BITOG.
Doesn't matter -- "paying more for cheaper components."
So the end result doesn't matter? Disagree.
How do you know the end result? You are taking Pennzoil's word for it.
Why even come to BITOG if company claims will convince you...?
Every company says their product is the "best" But the question is: define best?
I'm taking Pennzoil's word that it Exceeds API SN, HTO-06, GM 4718M, superior Seq IVA performance and a Tbn of 13. I never said it's the "best". If I did I was joking. It looks to be a premium oil though with very good specs.
Can someone detail to me the seemingly vast superiority of PAO over Shell's XHVI basestock?
Other then something along the lines of "OMG CUZ IT'S FAKE SYNTHETIC" because I'm really curious.
Wow!! When since using a synthetic product is overkill, especially on this site!? Some can say using synthetic over a dino is overkill especially since dino will easily go 5k or more and will easily protect your engine and keep it clean like synthetic will! Other than the high TBN, this product doesn't look any different than PP!
Very well put Buster, and spot on!
Group IIIs have better solvency than PAOs because their cycloalkane content contributes polarity. This is why Group III based oils generally do not require esters to solubilize additives and balance seals, as PAOs do. PAOs are utterly paraffinic and, while somewhat more oxidatively stable than most Group IIIs, have poor solvency properties and tend to shrink/harden seals.
Of the common base oils, POEs have the greatest solvency characteristics, followed by ANs, Group I, Group II, Group III, and PAOs.
That said, I'll repeat what I said here in the past: "Trying to characterize the performance of a motor oil strictly by its base oil composition is an entertaining but academic game."
Tom NJ
It's a pity that so many opinions on here can, at times, be negative diatribes about advertising and other such inconsequential things. What's really going to matter is the oils performance over various oci's utilizing oil analysis and real world applications. Attacking an oil (like Edge has been) especially before none of us have had any fair amount of time to make an accurate evaluation....is just sad. This new Ultra may be a very, very, good oil and do everything as advertised....or it may be nothing more than a Group III 'synthetic' with boosted cleaning additives. Time....and analysis...will tell.
It seems the main goal would be to get the most miles on an OCI with the least amount of wear. It seems to me that based on the many UOA's on this site that the best OTC oil would be the SOPUS oil's including YB. It doesnt realy matter to me about the base oil or group 3, 4, 5, or what ever. The end result is how it performed in the engine and I am pretty much sold on Pennzoil products now and trust that the company is producing a quality oil, including the new PU. Its easy to get and no mail order. Even the $28 bucks for the 5qt PU seems like a decent price to me.
Seriously. Can anyone tell me where people are getting Redline for $8 a quart? I'm in the market for some right now and don't want to pay the $11 on their site.
Unless you know somebody or wholesale it like I do you won't find it for that. Dougherbert.com used to have it for about 8 bux but the price recently went up. Oil is not cheap to ship and shipping cost have gone through the roof the past 2 years.
I think your seeing most companies raising the price of the product to offeset the shipping cost as people freakout when they see high shipping cost but that the law of the land these days. I drop ship huge amounts of product and I have seen a 50% increase in shipping cost over the past few years.
get a shipping quote on your own for a 18X18 box weighing 32lbs and see what the cost is. Youll flip a lid when see it
