So @High Performance Lubricants now has a CVT fluid (maybe David can give some insight on which CVT fluids this is a replacement for) plus the PDS has been updated. Enjoy!
Updated Product Page
They cry PAO?I heard it is made from the tears of Jatco owners.
I know; they’re working on updating it. That’s why I pasted the whole chart.When I pull up the PDS on HPL's ATF page, it doesn't show the CVT fluid.
I will stick to Honda HCF2....Not worth taking a chance....MaybeI will try the CVT fluid from @High Performance Lubricants . It too is PAO and Ester like the non slip I use from Redline. Hopefully it's HCF2 certification. Kinda been looking at the No VII 5w30 too as well as the Royal Purple HPS 5W30.
That's nice.I will stick to Honda HCF2....Not worth taking a chance....
HCF2? Might have to try if i ever use up all my Redline Nonslip CVT Fluid. Although the no tax and free shipping is pretty hard to turn down with what I'm using now LOLWell, the CVT is listed here through HPL's distributor:
https://www.advlubrication.com/products/automatic-transmission-fluid
524,000km Mitsubishi Mirage engine teardown
This channel has some teardowns on high-mile Mitsubishi Mirage with the Jatco CVT.
From the comments:
"I replaced the cvt in this car at 300,000km. Installed a used one. They can last longer than when you change the fluid more often, 50k km/30k miles seems to work. Right now there’s only with 536k on the same cvt and engine. A handful have over 400k km too."
So is this long life due to regular maintenance, the lighter chassis, or due to Mitsubishi's programming of the TCU compared to Nissan, etc. ?
Whats a good viscosity index range number for a really good cvt fluid like @High Performance LubricantsView attachment 206826
You should be able to calculate it from the 40*C & 100*C viscosities.Whats a good viscosity index range number for a really good cvt fluid like @High Performance Lubricants
Or Redline Non Slip CVT Fluid?
Mr. @HPL Plant Manager would be the best one to inquire with.The CVT fluid is no longer on the PDS on the site from what I can see. Is there a separate CVT PDS now?
