Originally Posted By: WobblyElvis
There are a couple of test you can do on the oil without any special equipment and only a few drops of oil.
The blotter test, a drop of oil is placed on a white business card.
The crackle test, a few drops of oil are placed into a hot frying pan.
These tests, and there may be more, can help detect water/coolant in the oil.
see here..
http://www.machinerylubrication.com/Read/101/visual-crackle-water
http://www.machinerylubrication.com/Read/499/blotter-spot-method
I actually mentioned the crackle test just did not use the proper name at the top of page 3 or 4. We use to do that away back. We use a space heater put a few drops on top if it smoked it was oil if it sizzled/steamed there is water/coolant in the oil.
The way I think of it is like if you want to test if a pan is hot you flick some water on it.
The blotter test never heard of I like it.
I went and picked up 4 feet of vinyl hose, a syringe so I can run the hose down the dipstick tube and draw some oil out. I am debating putting a weight on it so it does sink to the bottom of the pan. This way if the water settled I will draw up water. Once I got some from the bottom I was going to pull out a bit and grab some more.
My issue is without a weight I have no idea if the hose id floating or not. Then if you put a weight on and it falls off into the pan you could have much more serious issues. These oil pans are not an easy removal.
I hope they will let me do this like I say I do not want to keep going back and not giving them an answer.
