New harbor freight offerings
It does appear cups interchange if you remove the snap ring in the Snappys. And I think the snap ring will fit in the Icon cups.
The Icon uses three spring loaded balls rather than a snap ring for retention. The ring interferes with the balls, but I believe they'll engage the groove where the ring would normally reside. Likewise, without the ring the Icon cups just fall off the SnapOn arbors, but I believe the ring will fit the groove for the Icon balls.
In your opinion is it a quality tool? I would be interested in what you think after using it a few times, is the Snap on really worth $600 more? From the pictures it seems pretty impressive for $200.
Well, it seems quality, but yeah, I haven't used it at all. 90% of what I do with my BJ presses is u-joints. I may not have any actual ball joints to do for awhile, and that's the real test.
I didn't even look but I figure there's probably some YT reviews.
Also, I have not sorted through all the cup applications. The Icon comes with more, and depending upon coverage it might be worth getting the Icon at $200 for a couple more cups to supplement a BJP1, given that optional cups at SnapOn prices can hit $200 very quickly. This is also based on the ASSumption that Icon cups are not available outside of the whole BJJP16 kit (I don't know)
For the fan bois: I'm not excited about undercutting SnapOn per se, or American manufacturing, but I still believe competition is good for the consumer.
Trav,
I have both, and the parts interchange. It'll be interesting to track the longevity. I have already seen a broken c-frame on an Icon set.
Also I ASSume you've tried putting the snap ring in the Icons or removing it from the SnapOns and they stay together as they should?
It looks like it should work. Diameters are the same so the only variable I haven't had time to test yet is the groove itself, ie will the Icon groove accept the snap ring or will the SnapOn groove engage the Icon balls with snap ring removed.
Was the broken Icon frame on YT, a forum, social media or just personal observation? Not challenging you -- it would just be good to see a linkable reference if available.
Snap-On groove on the adaptor is retained by the Icon balls. That much I have done. The broken c frame was shown on the Youtube channel from CP The Tool Addict. I'm not a fan of his delivery so I'll leave it for others to search. Looking at his video, there might have been a pre-existing crack in that particular forging. I would love to get an actual look at it.
I decided to use my Icon BJ press on actual ball joints today. 2005 Explorer. So far it removed one side no problem.
HOWEVER, mine had a glaring annoyance where the spindle insert gets wedged in the spindle and must be pounded out. This is a HUGE time suck and I was unwilling to accept it, so I chucked them up and took several thou off.
I didn't bother measuring, I was annoyed and I don't see how being several thou undersize is the least bit of a problem. It works great after modification.
They're coated completely black so anything silver has been machined:
Other than that how was it to work with, any noticeable flexing? How much approx did you take off?
Honestly it was a joy to use. The three spring loaded balls seem more elegant than SnapOn's snap ring and they worked really well. HOWEVER, they seem more complicated, prone to contamination/intrusion, and less serviceable if one should fail.
Furthermore, I've done a total of ONE actual ball joint job with it (I did all four front BJs on this '05 Explorer), AND I was working with stamped steel control arms. Most old school steel knuckles (or inner C's) put up more of a fight if things don't go perfectly.
I used my big Milwaukee impact and didn't notice any appreciable flex.
I want to believe my spindle insert issue was a short-run manufacturing defect -- but man it was a PITA until I fixed it.
I actually ordered one yesterday because I predict prices will climb over $200 soon. If the metallurgy is decent I don't see how they're doing this at that price, and HF isn't afraid to flex a little with anything badged Icon.
I say it's a great day for the industry. Even if it's foreign market, competition is good for the consumer.
Quoting myself because I'm clairvoyant: retail now up from $200 to $230. I predict settling between $250 to $300 for awhile -- still a heckuva value compared to SnapOn
Also I see Maddox is offering a hydraulic line crimper to compete with the fancy Mastercool, but it's only ~$40 less
